Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    VXRacing ahead BigDov's Avatar
    8th February 2014
    630
    You will have reduced boost in 1st - 3rd with full boost being delivered after that
    Sent from my HTC One_M8 using Tapatalk
    MK5 VXR - Piper Turbo Back - Bilstien B8 Shocks - Eibach Sportlines - Whiteline RARB - Forge Re-circ( Yellow spring) - CDti intake - Direct feed hose Kit - Forge FMIC - Forge Actuator( Red Spring) - ANSU Fuel Pump - RnD stage 3 remap.
  2. #12
    24th April 2014
    70
    Forge recirc on a yellow spring with a stage 3 map, boosting around 1.5/1.6 bar. Was just a bar of vacuum with the green spring, if thats what you mean. Actuator as far as im aware is standard
