Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 41 to 50 of 62
Thread: Astra
  1. #41
    VXRed vocky's Avatar
    5th April 2015
    209
    Some extra info;
    I went from a CD400+ straight to the Navi 950, just by swapping the correct OEM parts shown in my previous posts
    VCI codes for retro-fitting Intellilink will only be given for post 2014 models
    It took several hours to carry out all the required VCI stuff, it is not a simple tick box exercise with a MDI Tech 3
  2. #42
    15,464
    I'll stick to my good old switch on with tech2
  3. #43
    5th April 2015
    209
    Added the Courtenay intake system to complete the stage 2 package
  4. #44
    5th April 2015
    209
    I changed the front brake pads today, they were the factory originals which had done 11750 miles in 30 months and still had just over 5mm left.
    I didn't want to have to change them over the winter months so another job crossed off the list
    I swapped over to Opel badges the other week, fitting the Opel airbag was the hardest part, otherwise it was very easy to do. The rear badge is actually stuck onto a round disc, not the hatchback door.
  5. #45
    5th April 2017
    212
    sexy as out ,mate
  6. #46
    5th April 2015
    209
    I have retrofitted an OEM rear parking camera, just above the number plate, next job is to get Rusty to work his magic to enable it
  7. #47
    1st April 2016
    185
    What do you need to get that all working?
    I have the Navi950 on MY16
  8. #48
    5th April 2015
    209
    It's not much wiring, just two screened wires to the rear of the Navi 950 control box, one wire from ignition +12v (sourced from the dash fuse box), one wire from reverse light feed and a 0v from the chassis.
    Hardest part was removing the bumper to cut the hole required. The Tech 3 is not quite so simple, some magic will be required to enable it due to the GTC never coming with the reversing camera from the factory.
    ps: it also requires the OEM rear parking sensors
  9. #49
    5th April 2015
    209
    Time for the third annual service - 14200 miles, roughly 4700 miles a year. Used some GM engine oil and a GM oil filter. Plus 2.3 litres of GM gearbox oil.
    I still have a set of electric folding mirrors to fit, which have been sat on the shelf for months. Hopefully get them fitted this year lol
  10. #50
    1st April 2016
    185
    Do the mirrors need coding?
