Results 1 to 10 of 16
    VXRed stevepym's Avatar
    9th April 2014
    130
    Question Corsa VXR Clubsport - Lowering
    Hi so iv never really lowered a car before so not 100% sure what I'm doing but i wanted to lower my Clubsport a bit without spending too much money and as its already got Bilstein suspension did want to change to much of that.
    So i was looking at just getting some springs and i saw these: http://www.europerformance.co.uk/pag...product=356350
    now it says "Lowers car by: Front: 50mm / Rear: 40mm" but thats a standard VXR right? so as the Clubsport it already lower by 20mm front, 15mm rear so these springs will actually lower my car by 30mm Front 25mm rear? assuming they would fit my suspension?
    Next question is this likely to cause any clearance problems bearing in mind the Clubsport has 18" wheels?
    Check out my insta for photos: instagram.com/stevepym
    9th April 2014
    130
    ah iv just realised those springs may be for a standard corsa?
    5th January 2014
    106
    Get Eibach Sportline..40/30 mm = 35mm 25mm for VXR
    You currently have eibach pro kit 30/30mm so with the Sportline your front gap will just close abit which IMO is perfect drop
    9th April 2014
    130
    Quote Originally Posted by brentg View Post
    but would be higher at the rear?
    5th January 2014
    106
    Not that high for me...remember people at back/sub etc etc.. and also over time springs will settle.
    Yes those from enhance are sportline.. check ebay might get it cheaper
    VXR enough helter_skelter's Avatar
    17th July 2014
    1,674
    Could always try coil overs then you can adjust them?
    Helters White nurb #083
    http://www.vxronline.co.uk/forum/sho...d.php?t=262442
    9th April 2014
    130
    people in the back wont be an issue now iv taken my seats out lol would the 45-50MM from EP be to low for 18" wheels then?
    9th April 2014
    130
    Quote Originally Posted by helter_skelter View Post
    Yeah wasnt really looking to spend too much for now, what ones are recommended though?
    VXRed Millervxr's Avatar
    26th October 2012
    143
    This is on 17'' 50/40 over standard vxr springs, the front is a a little too low IMO
