Results 1 to 5 of 5
    VXRed blooded D0959's Avatar
    3rd March 2012
    272
    Default Ignition Cut - Cobra Exhaust
    I'm sorry if this has already been discussed but I can't find the answer specific to my question.
    I currently have a 3" turbo back exhaust with 200 cell sports car and 1 resonated section. I understand that ignition cut will destroy the cat, but if I decat will ignition cut destroy the resonated section??
    Also does ignition cut damage the engine?
    Thank you for any sensible answers, sarcasm welcome
    VXR enough Arctic martin's Avatar
    27th December 2012
    4,278
    I'd say one box is better, and it can damage the engine if abused, I see a corsa with a valve that had come off and put a hole in a forged piston and ****** the engine
    WG Motorworks Fully forged Astra Vxr Arctic ...
    Rabbid tuned... TD Stage 3 hybrid, Piper valve springs, piper cams, klasen inlet manifold, Courtney cdti conversion, Airtec front mount intercooler, 3" scorpion exhaust, Turbosmart actuator, Forge recirc valve, Quaife LSD, Helix Clutch & SMF, Rear anti roll bar, blue & red SMD conversion , bi xenons and CD70
    3rd March 2012
    272
    What do you mean "1 box"?
    So if used with some common sense every now and then it should be ok?
    27th December 2012
    4,278
    Non resonated only have 1 box, the back box
    3rd March 2012
    272
    Thanks mate, I think I'm going to have to leave it then.
