Page 1 of 9 1 2 3 ... LastLast
Results 1 to 10 of 84
    VXRacing ahead joff-turbo-nova's Avatar
    6th January 2012
    697
    Default Project keeping the Mrs happy - number 3 !
    As some of you may be aware I have had two previous projects for the wife, her Corsa CDX and her current run around a 53 plate Meriva .....
    With increasing miles on the Meriva (its now over 120k) I thought it prudent to start sourcing a replacement vehicle. The wife plays double bass so we need something with a flat boot floor and a wide tailgate. The Meriva fits the bill , so why not stick with a tried and tested formula...
    So last year this nice little petrol blue Meriva popped up on Ebay as a Cat C accident damaged vehicle - only 35 miles up the road from home. I popped up to Scarborough, did a deal and it was delivered onto the drive accordingly......
    It's a '07 plate Meriva 1.8 Design with aircon, all electric windows and has only done about 42,000 miles.
    Needs a little attention at the front....
    I stripped the broken parts off just to make it a bit more tidy .....
    The aircon condenser was still gassed, even though it was banana shaped !!
    Seems that the car has hit a post which has taken out the crash bar, bumper, rad pack and bonnet - both lights are cracked and the n/s wing has a dent too. Its slightly dinted the engine bed, but everything looks straight and the panel gaps are OK ...
    Plans for the vehicle are :-
    - Replace dash as both airbags deployed - already sourced
    - Replace interior with a half leather VXR one (with retro heated rear seats) - already sourced
    - Replace panels on the front end - already sourced wing and bumper bar - had rad pack, bumper (with Irmscher lower spoiler) and bonnet in from previous Meriva VXP project
    - Major engine service (water pump, belts & idlers, filters, oil , brake fluid) - already sourced
    - Replace discs & pads all round - already in stock
    - Replace front arms and roll bar link bars - already sourced
    - Replace steel brake pipe for cunifer pipe all round - already sourced
    - Change flexi brake hoses for braided versions - already sourced
    - Change rear bumper to Irmscher item - already in stock from VXP project
    - Attached rear Irmscher spoiler & side skirts
    Cont/....
    Still not doing standard
    Meriva Z20LET/LEH project
    6th January 2012
    697
    Already started the modifying , as I have sourced a set of Omega Elite alloy wheels which were pretty shoddy...
    First job was get them to the media blasters for a strip....
    Then onto the sprayshop for some love and paint....
    So I thought it would be rude not to try them on my VXP project first ..
    They are wider (7.5") than the Astra alloys (7") and with an ET35 which makes life interesting in the clearance department on the spring cup - nothing that some 5mm spacers and longer bolts won't fix !
    I then put them onto where they are meant to be, the wife was very happy with the results...
    Some of you may recall I had a little incident in a car park with a steel beam jumping out at me which resulted in this...
    So I got busy with the repair and sorted it out like so - thought it would be a good idea to fit the other reversing sensor kit I have - these are the traditional sensor type....
    Masking tape, a tape measure and a bit of luck we got 4 holes marked out then drilled ready for the sensors...
    As luck would have it, I have a contact who let me know they were breaking a Meriva VXR and the interior was available. A deal was done and a pallet arrived a few days later....
    So it went into temporary storage in the garage...
    The bolsters on the front seats are quite worn and the usual issue with the foam bolster had started....
    Cont...
    6th January 2012
    697
    A couple of weeks later and the seats were ready for collection , looking almost like new, the pics don't quite do them justice as they look like new...
    Started work at the weekend stripping the front end off ....
    Removed the damaged wing and arch liner to reveal a nice clean chassis leg....
    In an effort to keep the rust away I thought it prudent to treat it to a couple of coats of hammerite, here's the first coat...
    Also tried some 5mm spacers to avoid any tyre/spring cup action which seems to have solved the issue...
    Next job is stripping the front brakes and suspension ready for new parts.
    Joff
    12th April 2009
    20,196
    Interesting read and a very good write up, will keep my eye on this!
    On another note your house looks top notch (Sorry, I'm turning into my dad lol)
    Opel Nürburgring Edition No.534 / IG - ItzMrGoodKat
    VXR enough Hxrry's Avatar
    8th January 2015
    1,921
    You certainly love your Meriva's! I read through your previous project when I first joined and now you've started another!!
    Good luck and the car is looking amazing already. Seats and alloys look mint!
    VXR enough Keif's Avatar
    12th March 2009
    1,906
    Nice one Joff, it was about time this project got it's own thread!
    Currently Driving - Lotus Carlton - Astra TwinTop - MINI Clubman Cooper - Nova GSi
    Written off - Meriva VXR
    VXR enough Sweet_vxr's Avatar
    25th April 2015
    1,526
    Can't wait to see more already, good stuff.
    Are you VXR enough? V13_URG's Avatar
    15th July 2012
    892
    Looking good you seem handy with the tools and the paint
    Do you have a thread for the nova in the garage anywhere? Looks a minter
    6th January 2012
    697
    Quote Originally Posted by V13_URG View Post
    Oh yes a big long one....
    http://www.pngclub.com/forum/showthr...highlight=joff
    Enjoy !!
    Joff
    27th May 2015
    27
    Interesting read, will keep an eye on this
