Results 1 to 3 of 3
    2nd March 2015
    11
    Default Front light settings (Face lift/a16, non-AFL)
    Hi there!
    Can anyone show, or confirm the light settings for the face lift front lights?
    I am almost certain mine are not working correctly.
    Link to the settings I'm talking about:
    http://s16.postimg.org/epj7kxid1/settings.jpg
    1st setting is all the lights off, with exception to Daytime Running Lights, link:
    http://s2.postimg.org/nh0sz24pl/1st_setting.jpg
    2nd setting all front lights are off (bar DRL), however the rear lights come on and you can put the fog lights on, link:
    http://s30.postimg.org/7mvlhf1zl/2nd_setting.jpg
    3rd setting all the lights are on (bar high beam), link:
    http://s17.postimg.org/psl029nu7/3rd_setting.jpg
    It's really bugging me, as I'm sure that the 2nd setting puts the front lights on dim..
    VXRed J3st3r's Avatar
    27th August 2014
    201
    That's exactly how they're supposed to work. The same as any other older car with the addition of DRL when the switch is set to off. 2nd setting is 'sidelights' which uses the weaker 2nd filament on the standard bulbs and is meant to be dimmer than DRL.
    White Corsa Nurb, WGM stage 3, full Cobra, Airtec FMIC etc, TD 1.2 17s, quickshift. Forged\cams, 240mm clutch, 330 Ksports.
    Rabbid mapped.
    2nd March 2015
    11
    Thanks for the quick reply, so it's absolutely fine, I was convinced that the 2nd setting turns the side lights on low and dims the DRL haha, ok thank you very much for putting my mind at ease
