Results 1 to 9 of 9
Thread: Dap R
    VXR Torque of the Devil jkemish's Avatar
    21st November 2013
    5,017
    Default Dap R
    Want to get some lowering springs for my vxr but I want to know if the dap r track springs will rub on the 19" alloys, also would the eibach 50/30 rub?
    Astra VXR Time Attack Build
    Follow me on Facebook at JK Motorsport
    https://www.facebook.com/JK-Motorspo...7132121985280/
    VXR Torque of the Devil vxrtricky's Avatar
    17th April 2008
    5,176
    if the eibach are the sportlines then no they won't I had them on mine before switching to 18s
    21st November 2013
    5,017
    Quote Originally Posted by vxrtricky View Post
    Thanks mate, so the eibach don't rub at all even on full lock ?
    15th May 2013
    17,902
    You'll be fine on DAP R mate.
    Just had a set fitted on my 18s which are an offset of ET30 and they look quite spaced out.
    No running and the ride is fantastic. Not harsh in the slightest
    21st November 2013
    5,017
    But is that the 30mm springs or the 40-45mm springs, don't think 30 mm will be low enough for me, but don't want it to rub
    15th May 2013
    17,902
    Mine are the Road spec.
    I didn't opt for the race spec as they are best on shortened dampers.
    Tbh with the 19s you'll be good on road spec as they look lower on 19s my 18s are like rota drifts and are hard to make look good unless low and still looks good on the road specs
    12th April 2009
    20,154
    I have them for my Burg and yes their 18s but I don't have any dramas with them, especially with going over speed bumps. Just tend to take it slower than usual (just personal preference) Long distance driving isn't to bad either
    Opel Nürburgring Edition No.534 / IG - ItzMrGoodKat
    17th April 2008
    5,176
    Quote Originally Posted by jkemish View Post
    Not that I remember. On 18s spaced out now and still no issues. Depends if you want **** up or **** down look tbh
    VXR Torque of the Devil PaulieMB's Avatar
    3rd October 2008
    7,783
    I had Dap R's on my Burg with 19" BBS CK's with an offset of ET35 and had zero rubbing issues, so you will have absolutely no worries with Dap R's on standard VXR 19's.
