Results 1 to 5 of 5
    VXR Torque of the Devil jkemish's Avatar
    21st November 2013
    5,017
    Default Evans Waterless Coolant
    Hello guys
    Just wondering if anybody is running Evans waterless coolant and if they think it's worth it.... I'm going to be servicing my car in the next few weeks and I'm just wondering weather or not I should use this, I know it's a lot more money but that doesn't bother me as long as the car is looked after and running fine
    Astra VXR Time Attack Build
    Follow me on Facebook at JK Motorsport
    https://www.facebook.com/JK-Motorspo...7132121985280/
    13th May 2008
    21,589
    Quote Originally Posted by jkemish View Post
    Hello guys
    Dont actually know how much this is compared to a decent premixed VX antifreeze mix, but any decent waterless coolant is far superior as it boils at 180deg as opposed to 100deg of water and slightly higher with additives and in a pressurised system which the Astra is, also if you ever get around the 100deg mark with road use ( most run at 96 very hard... mid 80's normally ) - this stuff would help look after your engine better, hence why race cars use it where high temps are present.
    If you use it, needs replacing at a similar interval to the VX stuff BUT DO NOT add any water to it or antifreeze naturally ..............
    21st November 2013
    5,017
    I will give it a go and let people know how it goes
    VXRacing ahead wissydean's Avatar
    26th April 2010
    534
    Having it done with rods & head beginning of Sept, will have to wait n see.
    Are you VXR enough? Mattyslost's Avatar
    2nd May 2015
    877
    Ive noticed since getting my gauges done that the water temp always rises to the 90-95c mark and thats just normal driving.
    How many litres of coolant do we need?
    Big Build Astra VXR Instagram - Mattyslost[/COLOR]
