Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: Finally RARB
    VXR Torque of the Devil jkemish's Avatar
    21st November 2013
    5,017
    Default Finally RARB
    Hi
    Finally managed to get my hand on a RARB, picked it up this morning on my way to work from a member on here
    Will be fitting it on Saturday, what setting would everybody suggest?
    Astra VXR Time Attack Build
    Follow me on Facebook at JK Motorsport
    https://www.facebook.com/JK-Motorspo...7132121985280/
    Does Vauxhall employ lazy ***** Stormtroopers? Michaelh's Avatar
    14th January 2010
    1,017
    hard or hard-medium
    2008 Black Shaphire Astra VXR Ko6 Hybrid Turbo, Airtec Stage 2 Cooler, Piper 3" Decat and Resonated, CDTi Airbox, Bilstein B8's with Eibach Sportline Springs, Whiteline Rear Anti Roll Bar, Wavetrac Diff, Ksport 356mm Brakes, 18" Revolution Milleniums and lots more
    15th May 2013
    17,909
    As above. As we will be moving into wetter months soon though I'd suggest medium-hard but tbh, it's not exactly hard to change
    21st November 2013
    5,017
    Got some track sessions in September at castle combe what would you suggest for on the track.... Leave it as it is or go for the hardest setting?
    12th April 2009
    20,162
    Quote Originally Posted by jkemish View Post
    Depends how your gonna drive, should be good on the current setting
    Opel Nürburgring Edition No.534 / IG - ItzMrGoodKat
    VXR enough 999VXR's Avatar
    24th October 2013
    1,205
    I've never put mine on hardest setting and I've been on track a few times, having rear a little bit loose gives you oversteer so you can keep putting power down, I find under steer to be the main problem on track so having it not to hard helps
    VXRed Jonnie_VXR's Avatar
    4th January 2015
    244
    I had mine fitted about a week ago. It was set to the 2nd setting from the softest and I instantly noticed a difference. I'm already thinking about making it stiffer. It really depends on how you drive your car.
    VXRed blooded KieranF's Avatar
    2nd November 2013
    317
    Hard-meduim. what an improvement it makes! its like a new car
    Astra OPC Nürburgring Edition #686. Instagram: @kieranfrith
    21st November 2013
    5,017
    Think that hard medium is going to be the one
    Can't wait till Saturday now hopefully get my new front splitter fitted aswell
    24th August 2009
    76
    Hard-medium for me, best mid I added to the car tbh
