Results 1 to 7 of 7
    20th October 2012
    7
    Default Lots of white smoke from exhaust
    Hi, I'm hoping I explain this okay as although I love my cars I am not the most engine savvy aha.
    When accelerating or revving at stand still there is lots of (edit)BLUE(edit) smoke coming from the exhaust. If you leave it at idle then rev it blows out in big waves.
    Less than 7 months ago I had the turbo replaced along with the manifold after it cracked.
    There is quite a lot of oil in the pipe from the intercooler before it goes into the engine.
    Does anyone have any ideas what could cause the smoke, is it an issue with the turbo? or could this be something else. I'm gonna run it down to my local garage to get an opinion on Tuesday but just wondered if anyone may be able to give any suggestions.
    Thanks in advance!
    VXR enough A Sad Napkin's Avatar
    13th July 2015
    1,236
    Car drinking coolant? I'm not 100% sure but I thought if it was the turbo it will be blue smoke?
    Regal Inlet Cam, (nice and lumpy idle) Pre Cat Delete, Fully Forged by WG Motorworks (Wosser 86.5mm Pistons, Molnar Conrods, Stem Seal Retainers). Crossover Delete Wtih RAMAIR. Rear Vibra Fast Road Mount, Polybushed front and gearbox mount, MTEC Dimpled and Grooved Discs with Brembo Pads Standard map Goodyears X4 Miltek Catback @ 245BHP
    20th October 2012
    7
    Hi, I made a mistake, the smoke is blue, as I wrote it I had just read a thread about white smoke, must have been on my mind.. I've updated the thread. All levels are okay currently. I did have to top the oil up about 150 miles ago, as it had gone down very low very quickly. Usually check it every couple of weeks.
    17th December 2010
    5,299
    Your description of leaving it idling for a while then giving it a rev, and blue smoke is present suggest that it could possibly be the valve stem seals.
    13th July 2015
    1,236
    Quote Originally Posted by Harber3 View Post
    Valve stem seals unfortunately. Common Problem.
    20th October 2012
    7
    Okay, appreciate the replies. Do you think I should not drive the car until it is sorted or is it something that could wait a week?
    13th July 2015
    1,236
    Personally I wouldn't wait.
    http://www.wgmotorworks.co.uk/repair...20-stem-seals/
    Read the above link, WG motorworks is good for those type of fixes.
