Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    VXRed bottlebill's Avatar
    11th September 2015
    199
    Don't know! Car is last of old shape but registration says "first reg Jan 2012"
  2. #12
    11th September 2015
    199
    Life begins at 60! Sport button left on - and I drive like a diesel!!
  3. #13
    VXRed Noxious89123's Avatar
    22nd June 2014
    141
    If it's the old shape then it's definitely an Astra H, otherwise known as a Mk5. So when you're buying parts you'll want to look for stuff for a "2004-2010" model. Your engine is a Z20LEH.
    Astra GSi ~ VXR Injectors / VXR 80mm AFM / VXR Turbo / CDTi Airbox / TS Recirc / K&N / 3" Piper Exhaust / CS FMIC / EBC YellowStuff / Bridgestone S001 / Bilstein B12 Pro-kit / Whiteline RARB
    CS Mapped 285 BHP / 340 Ft.lbs
  4. #14
    VXR enough VEE EX AR's Avatar
    14th August 2011
    1,521
    We need pictures!
    Pretty sure the last Astra H VXRs were on a 60 plate?
    WG Motorworks Stage 4+, Owens hta turbo, Piper Cams, Lightened flywheel, Quaife LSD ,356mm K Sports ,KW clubsports, Safety Devices cage, Sparco buckets, Aircon delete, 18in TD's, R888s.
  5. #15
    VXR enough Minismithy90's Avatar
    28th July 2010
    1,775
    I've seen a few VXR's on 11 plates.
    Fiesta Mk5 ZS>Fiesta Mk6 ST>Clio 172>Astra 'H' VXR>Fiesta Mk7 ST>Corsa 'D' VXR Nurburgring
  6. #16
    11th September 2015
    199
    Quote Originally Posted by Sean_VXR View Post
    Welcome, don't blame you may as well get smiles per gallon on your way to work
    Did Preston to Barnsley and back over the weekend and got 36.7 mpg. Better than expected ! Drove at 60-65 due to above average road works !
  7. #17
    22nd June 2014
    141
    36.7mpg!
    I'd kill for 26.7mpg!
  8. #18
    28th July 2010
    1,775
    Quote Originally Posted by Noxious89123 View Post
    36.7mpg!
    I used to regularly get 34 MPG from mine :P although i did drive like miss daisy to work and back lol.
  9. #19
    11th September 2015
    199
    I did 180 round trip at 60-65 mph all way and got the 36.7 mpg as per dash board !! Back to work Monday, mixed mway (80 mph) and b road, 80 mile round trip - back to 33 mpg !!!!
