Results 1 to 6 of 6
    VXR Torque of the Devil jkemish's Avatar
    21st November 2013
    5,017
    Default Bucket Seats harness
    Alright guys
    I'm ordering some sparco bucket seats for my VXR
    I have a harness bar but not sure where I would put eye bolts for down the sides of the seat...
    Does anybody have a pictures where they should or can go.
    Any help is much appreciated thanks
    Astra VXR Time Attack Build
    Follow me on Facebook at JK Motorsport
    https://www.facebook.com/JK-Motorspo...7132121985280/
    VXR enough Jackering's Avatar
    1st January 2014
    1,125
    Standard seatbelt mounts, you can get one down under the rubber on the door side.
    As for gearbox side I am told there are holes that can be used in the tunnel. Not sure how accurate that info is though.
    White VXR Clubsport.
    VXRo's own John Cleland Geordie076's Avatar
    3rd July 2008
    7,159
    sparco base mounts
    Tuned by RnD Motorsport
    VXRed blooded vxrchris91's Avatar
    11th March 2015
    319
    You got a harness bar for the longer rear straps?
    21st November 2013
    5,017
    Quote Originally Posted by vxrchris91 View Post
    Yes mate
    Just didn't know where the lap straps bolt into but seen they can either be welded to the chassis or bolt through the supports
    VXR enough 999VXR's Avatar
    24th October 2013
    1,205
    You can replace bolt that fixes seatbelt rail with hook eye bolt 40mm I believe then you pull heat sheild down on exhaust and drill 2 eyelets through quite far back and mount plates to support them
