Page 1 of 34 1 2 3 11 ... LastLast
Results 1 to 10 of 333
    VXRed blooded james400's Avatar
    22nd November 2015
    324
    Default getting to the 400 mark
    Hi guys I'm looking at getting the car to 400bhp so what is needed to get there as I've been told it's new turbo and injectors if so what turbo and what injectors ??
    VXR enough JamesPD1975's Avatar
    19th March 2013
    1,149
    What age is your car?
    19th March 2013
    1,149
    Quote Originally Posted by JamesPD1975 View Post
    22nd November 2015
    324
    It's a 2010
    19th March 2013
    1,149
    Is it in the weak chain range, ie before October 2010
    22nd November 2015
    324
    Well I'm going to pull the engine out to do the chain on it anyway it got on it front Mount/remap by quantum and decat
    19th March 2013
    1,149
    Okay buddy there are four things you need to sort out listed below before you head to those numbers,
    Chains if pre October 2010 speak to Nick150 cheapest who can do it and comes recommended by members on here.
    The Clutch (flywheel while you are doing it) the standard will not handle the power.
    The Haldex it will not deal with the increased torque now you can wait until it fails but that could cost 3k plus there is an upgrade route see Thorneys website.
    The Brakes with all that power you will need to stop the car the Brembos on the car are poor.
    Now you have done all of that you will require a full exhaust.
    Next a bigger intercooler
    Panel filter.
    Bigger turbo you can go Hybrid or if you go for something like GT30 then you will need pipework
    Injectors Bosch 550cc as a minimum.
    All of this will not leave you much change if any from 10k......
    Good luck getting to the 400 club..... See you when you get there 😁
    22nd November 2015
    324
    Ok cool well I have the panel filter I have a mishimoto intercooler and 2.5inch hard pipe boost kit so I'm on the way also have a gt3076r precision turbo in the garage is that OK to use?
    19th March 2013
    1,149
    Should be but I am not that mechanical. Big bad Bob is having an Owens version of the gt30 fitted.
    I'm currently on a Hybrid.
    19th March 2013
    1,149
    Don't forget the fuel pump it will struggle to keep up if you change the injectors
