Results 1 to 10 of 13
    VXRed Arctic edition 359's Avatar
    15th December 2015
    37
    Angry Corsa vxr turbo oil leak???
    right I have just found a oil leak today I was away to change fog light bulbs and spotted oil all over the intercooler pipes I thought it was the rad coolant at first but nope it's coming from the turbo, the pics are very poor but you can just see, can anyone tell me where and what's leaking and what's the best way to fix, new unit or seals?
    15th December 2015
    37
    VXR enough Arctic martin's Avatar
    27th December 2012
    4,278
    Have you checked the oil return pipe on the turbo I had a slight leak on the pipe due to the copper washer
    WG Motorworks Fully forged Astra Vxr Arctic ...
    Rabbid tuned... TD Stage 3 hybrid, Piper valve springs, piper cams, klasen inlet manifold, Courtney cdti conversion, Airtec front mount intercooler, 3" scorpion exhaust, Turbosmart actuator, Forge recirc valve, Quaife LSD, Helix Clutch & SMF, Rear anti roll bar, blue & red SMD conversion , bi xenons and CD70
    15th December 2015
    37
    no not yet booked into the garage next Wednesday so will find out then, for now no boosting haha
    VXRacing ahead Cobbie's Avatar
    23rd January 2013
    692
    As said before, looks like its coming from your oil return
    this is a quick and easy fix just need a new gasket there few quid from ebay
    Would like to know what the garage try charging you
    Good Luck
    Clique 19
    Jacob Newman
    Rabbid Tunned 410.1BHP - GTX2867r Shed Build
    15th December 2015
    37
    yeah I can't wait to see what they say, I've had a look and probably is that gasket will update when I know more cheers
    15th December 2015
    37
    I'm guessing this is the gasket I'll need ?
    VXR enough Jackering's Avatar
    1st January 2014
    1,125
    Yes
    Sent from my Nexus 5X using Tapatalk
    White VXR Clubsport.
    15th December 2015
    37
    nice I'll order one just incase it is this
