Results 1 to 8 of 8
    VXRed Jiron14's Avatar
    30th November 2015
    174
    Default Exhaust rattling.
    I've got a scorpion exhaust on my car. when I pull off slowly it must vibrate against my diffuser or something because it vibrates so loudly through my car. does anyone know how I can quieten it down? I've tried moving it about slightly but its so loud pulling off due to it.
    Does Vauxhall employ lazy ***** Stormtroopers? Michaelh's Avatar
    14th January 2010
    1,017
    take it to a exhaust place, they will move it properly, might need the hangers tweeking a little
    2008 Black Shaphire Astra VXR Ko6 Hybrid Turbo, Airtec Stage 2 Cooler, Piper 3" Decat and Resonated, CDTi Airbox, Bilstein B8's with Eibach Sportline Springs, Whiteline Rear Anti Roll Bar, Wavetrac Diff, Ksport 356mm Brakes, 18" Revolution Milleniums and lots more
    30th November 2015
    174
    Quote Originally Posted by Michaelh View Post
    ok. will try and locate the nearest exhaust place where I am. thanks!
    VXRacing ahead GymJunkie's Avatar
    25th February 2015
    525
    Just get under the car and move the exhaust around, see if there is excess movement or if its hitting anything.
    VXR enough X8 DUD's Avatar
    26th October 2012
    2,736
    Might be one of the exhaust heat shields that has come loose bud, as above get it to a garage and get it up in the air to check on it
    30th November 2015
    174
    Thanks guys will do!
    25th February 2015
    525
    so I guess no one fixes their own cars any more lol
    26th October 2012
    2,736
    Quote Originally Posted by GymJunkie View Post
    Not everyone is confident / comfortable with getting under their car to check these things out or knows what to look for
