Results 1 to 9 of 9
    15th February 2016
    27
    Default Led interior lights
    Just fitted LEDs tonight and now when opening the door the courtesy light doesn't work but if I switch it on it works fine has any1 had this problem before ?
    Thanks for any help
    7th February 2016
    8
    Have you checked the push pressure switch in the door isn't stuck that switch tells the light to come on when the doors open
    15th February 2016
    27
    Quote Originally Posted by Snowman93 View Post
    yeah checked that mate its fine can deal with it not working but just thought i would check see if there is a common fault with that happening
    thanks
    VXRacing ahead Dirty_badger's Avatar
    27th February 2015
    616
    Did you change the ones in the rear?
    15th May 2013
    17,156
    Quote Originally Posted by Dirty_badger View Post
    Rears are a right pain, i just couldn't get them to work at all. I ended up opting for 2 X heavily tinted blue 501 bulbs for about a quid on EBay, ok not as white as an LED but white enough and solved the problem
    27th February 2015
    616
    You've just gotta put a bit of tape on the rear bulbs, look at how the 501's are and then replicate that on the LED's.
    VXRacing ahead GymJunkie's Avatar
    25th February 2015
    525
    Here you go pal
    http://www.astraownersnetwork.co.uk/...-mk5-LED-guide
    Got LEDs in my rear interior light and they work great!
    I got some SMD LEDs and used a dremmel to sand off one of the + and - on opposite corners. Works a treat
    15th February 2016
    27
    Thanks for the help try it out tomorrow n see how it goes what about to courtesy light does that not work with led it comes on with switch just not when opening door
    VXR enough Probert993's Avatar
    21st September 2014
    1,256
    ;-) exactly mate
    Red calipers , factory fitted full AFL's , painted bootstrip , cobra Exhaust ,19 inch diamond cut alloys, full tinted glass,de wipered, metal pressed plates,maxton front splitter, Team heko wind deflectors, vxr grille badge...
