Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Power upgrades?
    5th March 2016
    63
    Default Power upgrades?
    Just recently bought an Astra VXR mk5, all body work and odds and ends I wanted are now done need to start looking at engine upgrades, anybody got any ideas where to start looking for maybe 350 bhp after a year I'd reckon, any help is appreciated currently sitting standard as of now.
    Ps what is a turbo back cat/exhaust?
    VXR Torque of the Devil vxrtricky's Avatar
    17th April 2008
    5,176
    Welcome. Hope your pockets are deep. Where are you based?
    Turbo back - from the turbo
    Cat back - from the cat so just the back part
    You will need turboback for 350bhp, most likely a 3" system
    Look on courts at the stages yo see what you need and a few build threads on here, some are running around that.
    I'd be surprised going from standard to that spec if you gave much change from 8-10k
    30th January 2014
    362
    3" turbo back intercooler ko6 hybrid turbo turbo smart recirc turbo smart Actuator forged rods stronger valve springs that's just basics want to do properly get tophat inlet mani cams fuel pump diff then map by rabbid
    20th September 2011
    1,021
    Not cheap getting that much power from standard bud,
    You would need to look at:
    3" turbo back (or a Remus that's 2.75)
    Front mount cooler (dna, airtec, forge, courts)
    Direct route with cdti or cone filter
    Fuel pump
    Inlet mani (klassen, eds, Romanian copy)
    Forging internals
    Cams with uprated single/double valve springs
    Turbo it self (Owens hta k06, TD stage 3)
    But then if your getting power I'd also recommend:
    Big brake kit (veccy setup, ksport, Alcon, ap's)
    LSD (quaife, mfactory, wavetrac)
    Rarb (white line)
    Springs/shocks or coilovers
    Solid engine mounts (vibratechnics or polybush inserts
    These are just some things I'm sure people would suggest or change some of the above
    VXR enough Arctic martin's Avatar
    27th December 2012
    4,278
    You won't need fuel pump but you will need bigger injectors
    WG Motorworks Fully forged Astra Vxr Arctic ...
    Rabbid tuned... TD Stage 3 hybrid, Piper valve springs, piper cams, klasen inlet manifold, Courtney cdti conversion, Airtec front mount intercooler, 3" scorpion exhaust, Turbosmart actuator, Forge recirc valve, Quaife LSD, Helix Clutch & SMF, Rear anti roll bar, blue & red SMD conversion , bi xenons and CD70
    30th January 2014
    362
    Defo don't need bigger injectors not for 340 350 I ran 348 with vxr injectors for well over a year
    30th January 2014
    362
    Quote Originally Posted by tiny87 View Post
    Fuel pump
    Forging internals
    Rarb (white line)
    Spot on with what u said mate plus do it properly you do it once
    VXR enough stevenbarrowVXR's Avatar
    21st November 2013
    3,934
    You might have ran std injectors but they be very close to their max duty cycle at 340-360bhp and for sake of £160 for bigger injectors its not worth not upgrading them and getting them mapped in for safety. I would also advise an uprated fuel pump, again not worth the risk and the condition of the pump and std injectors get worse over time and their capability can suffer so it really is risky not changing both, most tuners would recommend upgrading both at that power level for safety, doesnt mean std pump and injectors cant handle that power but both on their limit and any weakness in either could be disastrous
    Rabbid Tuned Stage 4.5 - 355bhp - TD S3 Hybrid, AET ported exhaust manifold, TS 10psi actuator, TS recirc valve, Full 3" Piper decat non-res exhaust, Forge intercooler, AEM dual nozzle WMI kit, cdti hose with AEM cone, Regal cams, Klasen inlet manifold, Piper single valve springs, Percy retainers, PEC i-beam rods+ARP bolts, Skimmed Head, Protec 340lph fuel pump, Siemens 630cc injectors, AP front big brake kit, Vectra VXR rear brake conversion
    30th January 2014
    362
    Quote Originally Posted by stevenbarrowVXR View Post
    You might have ran std injectors but they be very close to their max duyy cycle at 340-360bhp and for sake of £160 for bigger injectors its not worth not upgrading them and getting them mapped in for safety. I would also advise an uprated fuel pump, again not worth the risk and the condition of the pump and std injectors get worse over time and their capability can suffer so it really is risky not changing both, most tuners would recommend upgrading both at that power level for safety, doesnt mean std pump and injectors cant handle that power but both on their limit and any weakness in either could be disastrous
    Ye no disagreement there but yet again it's a factor of how much he wants to spend and if he wants to do it properly and again if mapped by someone who knows there **** ie rich there will be no issue running that but as stated if he wants to do it properly go all out and spend the money same as matey saying u don't need fuel pump but for £200 quid to upgrade both its well worth it
    27th December 2012
    4,278
    Quote Originally Posted by matty_burg737 View Post
    Defiantly do mine are maxed out at 340 and mapper will not touch the car again unless bigger injectors are fitted
