Results 1 to 10 of 12
Thread: Exhaust noise!
    VXRed Jiron14's Avatar
    30th November 2015
    174
    Default Exhaust noise!
    Other than buying a new set up is there any ways to reduce the noise of my exhaust? It's so loud. It sounds great when you're booting it but pulling off and idling around town it's so loud and sounds ****. What can I do to reduce the sound? It's a scorpion decat.
    VXR enough Arctic martin's Avatar
    27th December 2012
    4,278
    What 3"?
    WG Motorworks Fully forged Astra Vxr Arctic ...
    Rabbid tuned... TD Stage 3 hybrid, Piper valve springs, piper cams, klasen inlet manifold, Courtney cdti conversion, Airtec front mount intercooler, 3" scorpion exhaust, Turbosmart actuator, Forge recirc valve, Quaife LSD, Helix Clutch & SMF, Rear anti roll bar, blue & red SMD conversion , bi xenons and CD70
    30th November 2015
    174
    Quote Originally Posted by Arctic martin View Post
    What 3"?
    Not sure. I would imagine so.
    18th January 2016
    54
    Quote Originally Posted by Jiron14 View Post
    i think you need to put a silencer in there probs save you buying a new set-up mine is a cobra exhaust and is stupid loud
    VXR enough X8 DUD's Avatar
    26th October 2012
    2,728
    Put a center silencer in, will reduce the cabin drone and quieten it down. Different silencers for different jobs, can get a reflection one which redirect exhaust flow through chambers in the silencer or you can get an absorption type which essentially has noise absorbing material around the center pipe in the silencer.
    Have a look on here: http://exhaustsilencer.eu/index.php?...ers&Itemid=621
    27th December 2012
    4,278
    If it is I got a resonated one we can swap a few bits over is your not to far from me
    30th November 2015
    174
    Thanks everyone!
    VXR enough 999VXR's Avatar
    24th October 2013
    1,205
    Second silencer like mine, also sports cat, powerflow do a good one that just chops in place I have a scorpion silencer mated to powerflow second silence lol
    7th November 2014
    354
    Your car does indeed sound awesome when you pull away Josh!
    Never thought about suggesting a sports cat to you.Mines running one.
    30th November 2015
    174
    Quote Originally Posted by Dalekboy View Post
    Might have to look into that! still a newbie to good cars like these lol!
