Results 1 to 10 of 10
    VXRed tomadcockvxr's Avatar
    16th May 2015
    43
    Default Corsa VXR Bilstein B12 with 20mm Spacers
    Hi Guys,
    Just wondering if anyone has the bilstein B12 kit running with 20mm rear spacers and 16mm front. As I want to get the B12 kit because first of all i need new sus as it scrapes going over bumps because the rear shocks have lost all there oil and secondly who wouldn’t want them!!
    25th September 2013
    1,063
    20mm rear is way to much , will rub like mad 10mm will be ok .
    stage 3
    16th May 2015
    43
    Okay thanks! Is it worth the upgrade to the B12 kit?
    It's an orange thing! craigyvxr's Avatar
    17th April 2007
    3,532
    What scrapes? The dampers dont determine the ride height, thats the job of the springs regardless if the dampers have leaked or not.
    Are you sure the archliner hasnt warped and thats touching the tyre?
    236BHP 260lb/ft
    Green Hell Club
    Team Oldskool - Bring back the good old days!!!
    16th May 2015
    43
    I'll have a look, good idea!! Thanks mate!
    16th May 2015
    43
    Just checked the archliner and it all seems okay, it happens a lot more when someone's sat in the back and defiantly sounds like it's coming from the back, passenger side.. Would the spacers be causing this?
    VXR enough DV1989's Avatar
    16th October 2006
    2,689
    The rear wheels sit fairly close to the Arch standard so having 20mm spacers on pushing the wheels out will rub everytime you go over uneven ground which is everywhere in the UK
    Chilli Orange Corsa Nurburgring, No. 011
    16th May 2015
    43
    Okay thanks mate! I live in the Isle of Man which has even worse roads so count your self lucky! 😂
    28th July 2014
    9
    the B12 are great, but don´t run spacers in general they destroy the bearing and on a corsa they are rubish to start with.
    23rd May 2013
    2,246
    I would suggest if you live somewhere with bad roads you keep the standard suspension.
    The B12 is lowered and stiffened so it will exaggerate the feeling you get going over potholes as well as reducing clearance slightly.
