Results 1 to 10 of 10
    VXRed Xxpeakxx's Avatar
    5th May 2016
    19
    Default Footwell lights???
    I want to buy footwell lights on my white Astra vxr nürburgring , but not sure what ones to buy and where I should wire them. ??
    25th May 2016
    3
    Get led strips from ebay like these Look at this on eBay http://www.ebay.co.uk/itm/321810192393
    And you can wire them to the back of your cigarette lighter and a swicth if you wanted to be able to turn on/off
    9th May 2016
    24
    I'd assume to wire it into the back of the cigarette lighter is a simple case of removing the cigarette lighter then just soldering the wires into the wires that are there?? newbie to all this stuff so sorry if its a bit of a stupid question
    Arden Corsa D VXR
    18,467
    If you want to be really clever you can wire it to the courtesy lighting so it fades in and out. Slightly more tricky though
    9th May 2016
    24
    that sounds a bit complicated for someone who has never messed about with car electrics to me
    Arden Corsa D VXR
    VXR enough corsa-del68's Avatar
    18th February 2011
    3,346
    Quote Originally Posted by C4RBON94 View Post
    I did my corsa mate and its pretty easy,couple of hours max and far better than a switch from cig lighter
    black sapphire corsa vxr stage 3 241.7 bhp & 250 lb torque 3 piece remus..30/20 P.I lowering springs. vxr badge front and rear. blue smd conversion..insignia washer jets...18" diamond cut alloys...pipercross cone...forge brace bar...de-badged...smoked side repeaters..airtec intercooler,forge recirc valve,cool runnin stat,390cc injectors,courteney fuel pump and full courteney hose kit..mtech short shifter
    VXRed STEVE GRIFFIN VXR's Avatar
    1st January 2016
    182
    I guess power to cig lighter is constant or just with ignition on?
    18,467
    Quote Originally Posted by STEVE GRIFFIN VXR View Post
    Constant. It is on these astras. I can charge my phone when ignition is off
    11th June 2016
    177
    Just ordered mine from eBay will upload photo when installed. Live the idea off footwell lights.
    20th September 2011
    1,021
    Mine have been fitted to look oem, come on when courtesy light comes on...
    Also have puddle lights under the door card
