Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 41
    VXR enough John w's Avatar
    5th January 2014
    1,533
    Default Have you had intermittent boost loss? Maybe this may help [emoji849]
    Couple of weeks ago I had a total boost loss and eventually a engine light on the dash.
    Checked fault code p00013 cam solenoid b open bank 1. This fault became intermittent and boost came back and went again over a few weeks. To cut a long story short the exhaust vvt solenoid had become faulty!! to check this use a ohms meter on the pins (disconnected) they should read between 8-15 ohms if not then the solenoid should be replaced. Mine read 13.2ohms on inlet and 168k ohms on exhaust. Ordered new solenoids for both, replaced as re check no fault code no engine light and full boost regained. Common fault on the lhu engine pins become loose inside solenoid and give intermittent fault sometimes without engine light on dash. I know a couple of people have had boost loss on here before so thought I would post for info.
    Had them in for a couple of days now and no further problems fingers crossed lol 👍
    Arden Blue / Areo pack / Navi 600 / Xenon AFL lights / DAB /Bluetooth / LED DLR,S/ LED number plate lights
    LED rear lights rear park assist / K&N panel filter
    20" rims 279 BHP
    Miles of Smiles
    10th January 2015
    445
    A good mini how to,this is what forum's are all about sharing information and building knowledge
    VXR enough wardy's Avatar
    22nd September 2006
    2,134
    That's good to know.
    It may be something completely different but when I floor mine right through the revs, I get the power coming in in 'steps'. Its not bothering me really, I'll let it develop and if it gets worse then the vvt solenoids will be worth checking.
    VXRacing ahead Giancarl03's Avatar
    18th February 2014
    549
    Thanks John. The resistance info is very useful thank you once again.
    -=2014 Astra OPC=-
    Summit White|Aero Pack|206kW|400Nm|1530kg
    VXRed tomelmer's Avatar
    31st August 2016
    108
    i've ordered a set of these myself in hope that mine could be on there last legs gonna check the voltage again today but they have all checked out so far.
    VXRed Mjrsharpe's Avatar
    8th February 2016
    151
    Great info ! How much do they cost if you don't mind me asking ? Thanks
    5th January 2014
    1,533
    They were about £110 each from autovaux took about 3 days to get 10 mins to fit ask for Carl or tim
    20" rims 279 BHP
    Miles of Smiles
    31st August 2016
    108
    Just checked mine John there 11ohms on intake and 11.2 ohms exhaust
    14,735
    They're all good lads at autovaux, Carl, Tim, kieron.
    5th January 2014
    1,533
    Quote Originally Posted by tomelmer View Post
    You may need to check for leaks mate if these are ok.
    Also check dump valve spring and diaphragm as a first check mate.
    20" rims 279 BHP
    Miles of Smiles
