Results 1 to 6 of 6
    VXRacing ahead spidasingh's Avatar
    26th April 2010
    651
    Question Fluids for the Insignia
    Service time is due soon, just wanted to know what fluids people are using
    Engine Oil
    Brake Fluid
    Gearbox Fluid
    Dont mind if its stock, just wanted an idea, I do have the AP racing 6 pots with AP brake fluid, but wanted to know if there is a better recommendation. Insignia is Stage 4.
    Just need your thoughts.
    19th January 2016
    56
    from everything I've read, the default Vauxhall oils are the best to use. Not sure about a modified car.
    21st July 2014
    645
    Millers CFS Nanodrive engine oil, it's a top tier ester synthetic. It's expensive but dyno proven torque and BHP increases
    26th April 2010
    651
    Thanks. I was using Fuchs Titan Race Pro S. Also ester based. Much difference between the two?
    Sent from my ONE E1003 using Tapatalk
    21st July 2014
    645
    Nanodrive has dyno proven bhp and torque gains due to the anti-friction additive, other than that both are top quality oils. If in doubt, ask the oilman 👍🏻
    26th April 2010
    651
    Went with Nanodrive, and Motul RBF660
