Page 12 of 14 FirstFirst ... 2 10 11 12 13 14 LastLast
Results 111 to 120 of 138
  1. #111
    18th April 2013
    306
    Your car is great.
  2. #112
    VXR enough Minismithy90's Avatar
    28th July 2010
    1,807
    A few days ago, gave the VXR it's first good Clean of 2018 and fitted some things to freshen it up,
    Misc by Michael Smith, on Flickr
    Consisting of,
    *Number Plates
    *Citroen C2 Aerial
    *VXR Valve Caps
    *VXR Badge
    VXR by Michael Smith, on Flickr
    Hole by Michael Smith, on Flickr
    Plates by Michael Smith, on Flickr
    Empty by Michael Smith, on Flickr
    Aerial by Michael Smith, on Flickr
    Little things to just freshen the ageing exterior up.
    Clean by Michael Smith, on Flickr
    Jobs a good'un
    Fiesta Mk5 ZS>Fiesta Mk6 ST>Clio 172>Astra 'H' VXR>Fiesta Mk7 ST>Corsa 'D' VXR Nurburgring
  3. #113
    VXR enough baillie89's Avatar
    18th February 2015
    1,098
    Looks brilliant! Very well cared for, good to see!
  4. #114
    VXR enough yodacraig's Avatar
    25th January 2010
    3,059
    Looks well nice mate I give up fitting valve caps to my cars kids always pinch them lmao
    xbox addy -turboyoda85
    Instagram yoda_craig85
  5. #115
    28th January 2018
    4
    Looks so clean and well looked after. Also love that colour ��
  6. #116
    28th July 2010
    1,807
    Bit of an update, and to cut the long story short my Drivers side Brembo Caliper has failed, i had my suspicions for a few weeks that it was on its last legs with various symptoms. Anyhow bought 2x new Brembo Calipers and the ones that arrived where the ones fitted to the Performance Packed Corsa E VXR's.
    Brembo by Michael Smith, on Flickr
    All that's different is the Carrier/Spacer or whatever its called that allows it to use 330mm Discs.
    Spacer by Michael Smith, on Flickr
    Above Carrier for the E Corsa VXR with Performance Pack with 330mm Discs
    Above Carrier for the D Corsa Nurburgring & Clubsport with 305mm Discs
    Quite a difference tbh!
    So instead of messing around trying to swap Carriers over i bit the bullet and bought the 330mm whoppers instead
    330mm by Michael Smith, on Flickr
    Nice difference, and it'd be rude not to fit from HEL Hoses,
    HEL Hoses by Michael Smith, on Flickr
    Manged to fit the Passenger side fine,
    Hose by Michael Smith, on Flickr
    Nice and easy, now the Drivers side, hmm it all seemed to be going according to plan until the last few threads and it just kept spinning and spinning and fear of losing all my Brake fluid i nipped it back up and i'll attempt it tomorrow once i top up the Fluid! and hopefully Bleed them all. Failing that i'll refit the OE Hose on the Passenger side and go from there!
    Tar
  7. #117
    28th July 2010
    1,807
    Still had problems with the Drivers side Hose so in fear of knackering it up completely, this morning refitted both the OE Hoses back and bleed the Brakes.
    Only been around the block as they need 'bedding' in but i can tell the difference straight away! Love it
    So to recap, my Nurburgring has the Remus Back-Box from the Corsa E VXR and now the Brembo Calipers and the 330mm Discs from the Performance Pack Corsa E VXR.
    Next up i really want the Alloys a refurbed and the Rear Calipers painted. Just under 38k on the clocks now.
  8. #118
    28th July 2010
    1,807
    Received a letter from Vauxhall yesterday, regarding a recall on the Handbrake. Can’t say I’ve noticed any issues if I’am honest, but it’s gotta be done.
    Booked it in for next Friday. Anyone had there’s done and if so, noticeable difference?
  9. #119
    18th April 2013
    306
    I love it. Where do you purchase big brake kit and for how much? It's big different to 305 mm? This will be my next upgrade.
  10. #120
    28th July 2010
    1,807
    Quote Originally Posted by AljazK View Post
    Cheers mate
    https://rover.ebay.com/rover/0/0/0?m...2F263570184559
    Got them from Nevlock Shop of eBay, and as you can see they come with the Carriers that allow the bigger Discs. Then local Brakes International for the 330mm Discs. At around £90 for the pair IIRC.
    I’ve noticed quite a noticeable difference tbh.
