Results 1 to 10 of 16
    18th August 2016
    42
    Default Lowering vxr 60mm??
    Thoughts on lowering the vxr 60mm?
    VXR enough Craig 522's Avatar
    12th February 2013
    2,160
    Too much. Not unless your doing it properly. You won't actually have a lower centre of gravity and it'll make your car handle like s4it
    22nd September 2015
    115
    Bad idea
    12th April 2009
    20,162
    Quote Originally Posted by VXXXR View Post
    You using Air? lol
    Opel Nürburgring Edition No.534 / IG - ItzMrGoodKat
    15th May 2013
    17,909
    Go to a VAG forum lol.
    Not something I'd personally do
    12th February 2013
    2,160
    I agree not a good look on any vxr imo
    Also it seriously affects the handling. You should in theory add a roll centre kit. But unfortunately there isn't one for the corsa D. When you lower a corsa the wishbone etc ends up sticking up in the air and not facing down or at least level. Anyone who has a lowered corsa will have this to some extent but 60mm will be too much strain. It's same principle as holding a bucket of water as high as you can instead of carrying it at arms length
    18th August 2016
    42
    No worries cheers mate, if I were to out springs on it, what night springs would be best for handling?
    VXR enough DV1989's Avatar
    16th October 2006
    2,689
    Will not be just Springs you would be looking at for handling improvements you will need to look into Anti Roll Bar upgrades, Torsion Bar etc. Anything to make the Car more rigid while playing around with Suspension.
    Chilli Orange Corsa Nurburgring, No. 011
    23rd May 2013
    2,414
    Eibach or PI springs would be best - 30-40mm drop.
    £90 - £140 quid off ebay.
    Are you VXR enough?
    5th March 2016
    855
    Mine is the blue edition vxr which as uprated suspension over std and I have never felt the need to change suspension or lower it, it handles so good 60mm lower WHY? It won't handle that much better , it will scrape on all the crappy roads and bumps and imo look stupid , 30mm is more than enough with a decent Bilstein or top brand set up you can't go wront
