Results 1 to 10 of 14
    VXRed Spooner1978's Avatar
    28th August 2012
    100
    Default Tyre pressure sensor
    Got in car this morning and it was telling me front drivers side tyre was low even tho both fronts was on same pressure on screen both at 34 psi so got compressor out garage to c what was in and it only had just over 20 psi so what's the point with the tyre pressure sensors if they tell u the wrong pressure
    25th July 2013
    46
    I'm wondering what happens if you get a puncture, and use the tyre sealant. will the sensor become stuffed along with the tyre !!
    4th January 2016
    23
    My system has never worked from the day it was delivered, always got the yellow warning light on, Vauxhall are not interested, so neither am I, it will go back from lease like it.
    VXR enough insanejim69's Avatar
    18th July 2008
    4,193
    If the pressure went down over night it will still read the old pressure on screen, as soon as you drove it would have changed. Or at least thats what the TPMS was like in my Insignia. It had a delay, but the DDS system is terrible it has such a delay its unreal.
    James
    25th July 2013
    46
    Just discovered today that tyre pressure monitor sys are mandatory. EU regs since 2014. All new cars since then have to have them. It's also an MOT fail if they don't work. Hoping even if they give false readings, they're still sending data, so classed as ok !!!
    Found info on ATS tyres web page.
    13th April 2017
    1
    Does anybody know how to get rid of the TPMS warning light? Tyres are at optimal pressure yried holding the set button in but only get a learn tyres option and light still stays on
    30th June 2015
    58
    Question
    Mine has been playing around for months on end and I was going to book it in for a warranty repair but from the comments on this thread i'm assuming dealerships don't fix the issue?
    4th January 2016
    23
    I had the problem from day one, it was delivered with the warning light on, after trying the reset time after time with no luck, I gave up & ran it to its first service like it, got sorted with a new valve / pressure sensor in the r/h rear wheel, as the car never connected with it, no issues since.
    30th June 2015
    58
    That's more promising so just booked mine in to get it looked at.
    VXRacing ahead Euro's Avatar
    7th November 2011
    629
    Not really confidence inspiring for me to swap my perfect Club sport for a new E model......and just when I was getting excited about doing so
