Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: key fob TROUBLE
  1. #11
    VXRed Mays7's Avatar
    22nd March 2013
    30
    guys going to try the keys! tonight.
    how do you do it?
    THE RED ARROW
  2. #12
    10th July 2013
    281
    Quote Originally Posted by Mays7 View Post
    how do you do it?
    Any luck?
  3. #13
    VXRed blooded VinPetrol's Avatar
    13th June 2016
    370
    I had a similar issue the other day. Car would unlock but just wouldn't start. Came up with 3 fault codes 65070 161450 and 161600 (I think). Eventually after several attempts, the car started. Changed the batteries on the fobs and (fingers crossed) it's been ok since.
    Checked my owners manual and it said there should be a tiny T-shaped key inside the fob for emergencies, but both mine are missing. It shows that you can get access to the car with this but don't know if you can start it as well (I presume you pull that cover off where a normal key should go and stick it in there).
    Went to Vauxhall yesterday to get one and they said it would be about £120!! But I needed to have my V5 with me and some ID which I didn't.
    Seems a bit steep that!
