Results 1 to 10 of 12
    VXRed danlee's Avatar
    30th March 2013
    21
    Default Which Gearbox Oil?
    Hi,
    I know this has probably been asked a million times but here I go..
    Standard Astra H VXR. Want to change the gearbox oil.. What are people using that they'd suggest?
    Many thanks,
    Dan
    Regional Assistant - Scotland West f1slikki's Avatar
    20th May 2009
    1,468
    I use redline MTL 75w/80 can't fault it box is silky smooth,think others use Titan sinofluid 75w/80. Which get good reviews too
    Arden Astra H VXR/Stage 2/6k Afl's/19"Gloss Black Alloys/Powerfold Mirrors/Sight & Light Pack/Parking Sensors/Keyless Entry,Start/Full Remus&Oil Restrictor Bolt By Jigger/Blue,Red SMD By Stampede/Drilled & Grooved Discs/Tints/Green Cotton Filter/Carbon Iinlays/VXR Grill Badge/Private 3D Gel Carbon Plate/Team Hekos/Stubby Bmw Ariel/Debadged//Indicator Surrounds/C,C Bootstrip/Led Side & Plate Lights/VXRO Stickers/
    19th January 2014
    1,800
    Quote Originally Posted by danlee View Post
    Hi,
    Many thanks,
    Dan
    You've now made it one million and one.
    Any of the fully synthetics 75W90 OR 75W85 as they're all much the same
    OPC ÉIRE
    30th March 2013
    21
    Hahah yeah sorry people.
    I appreciate the help.
    Dan
    VXR enough c19urg's Avatar
    24th April 2011
    2,108
    Court/ Sport recomend Valvoline Syn Power TDL 75w-90 or Amsoil MTG 75w-90
    15th May 2013
    17,624
    Fuchs Sintofluid 75-80 also worth a mention. That's what I use
    VXRacing ahead vexorg's Avatar
    8th March 2015
    703
    Well, thats clear as mud, several different oils to choose from. Given the reputation of the M32, I would have thought there would have been a more agreed oil.
    David
    15th May 2013
    17,624
    Tbf, GM stuff will do the job provided it's changed often enough.
    I'd have a look at the above suggestions and see what you can get cheapest
    13th May 2008
    21,589
    ^^^ spot on and best advice imo !
    Oilman once stated that if you have a worn gearbox you shouldnt be using better OILs anyway as it will make the g/box even worse.
    Should you just had a g/box refurb' and have plenty of available cash - buy the best you can afford ............
