Results 1 to 10 of 19
    VXRed deanoreynolds's Avatar
    21st August 2010
    239
    Default 2009 VXR's Still going?
    Hi all,
    Looking at an Arctic tomorrow in Essex.
    Number. 80 (2009)
    It's not on the arctic register here, only has 53,000 on the clock.
    Wondered if any of you guys with VXR's in the 2009 era are still running strong?
    Had a 2009 VXR about 4 years ago, nothing but issues so I sold it, which has caused my apprehension to appear, so thought id look to get some comforting advice... If there is any!
    Arctic Edition No. #080
    VXR enough A Sad Napkin's Avatar
    13th July 2015
    1,169
    Why wouldn't they?
    Check Service History.
    Check previous MOTs (only need REG to do this)
    Check Gearbox
    Check tyres (if budgets then cars probaly been cheaply looked after)
    Check IDLE on cold start
    Check for any smoke etc.
    Regal Inlet Cam, (nice and lumpy idle) Pre Cat Delete, Fully Forged by WG Motorworks (Wosser 86.5mm Pistons, Molnar Conrods, Stem Seal Retainers). Crossover Delete Wtih RAMAIR. Rear Vibra Fast Road Mount, Polybushed front and gearbox mount, MTEC Dimpled and Grooved Discs with Brembo Pads Standard map Toyo PRoxes T1R's X4 @ 245BHP
    21st August 2010
    239
    Thanks for that.
    Didn't even know about the MOT history!
    Tyres I can check.
    Has full service history that I can view
    Will check idle tomorrow when i view
    Smoke too...
    Gearbox - not sure on that.
    Thanks for the reply.
    13th July 2015
    1,169
    Quote Originally Posted by deanoreynolds View Post
    Thanks for that.
    Tyres I can check.
    Smoke too...
    No worries.
    Check for Diff/Gearbox whining and if the gear stick jumps back when lifting off accelerator.
    Yeah for example if the car constantly fails mot etc
    Another thing to check is lift the clutch up fast to biting point and if theres any clunks etc.
    13th July 2015
    1,169
    Check for receipts for gearbox rebuild, cambelt and water pump etc.
    21st August 2010
    239
    Was all sweet!
    Thanks for the help.
    13th July 2015
    1,169
    Glad to hear. I rushed into buying mine and needed a full rebuild down the line lol
    Sent from my Redmi Note 3 using Tapatalk
    10th September 2016
    92
    I've had my 2009 Corsa VXR with 56k a few weeks now and aside from it needing a new blower fan and having a whining gearbox its been all right.
    21st August 2010
    239
    It's just the apprehension carried on over from my last.
    New radiator and more which costed £1,500... Warranty covered it but still annoyed me as only a month old.
    This Arctic has only had 1 lady owner from new, 53k, all vauxhall history, all previous MOT failings and receipts of work carried out from Vauxhall.
    So fingers crossed...
    21st August 2010
    239
    Quote Originally Posted by A Sad Napkin View Post
    Not good! lol. I went to town on inspecting it.
    Don't see many VXR's my way.
