Results 1 to 9 of 9
    18th August 2016
    42
    Default Very Strong smell Of Petrol While Driving
    Happens after driving for 20mins. No leaks and can't be smelled on the outside. Its very very overwhelming. Any thoughts? Its a 2007 Corsa vxr
    YouTube: JDM DRIFTERz Remus 3 Piece, Regal RSS DV, Pipercross Cone
    VXRacing ahead Tom{BSc}'s Avatar
    29th January 2011
    585
    Happens to me sometimes. I just pull over and screw the fuel cap up a little more. Fixes it every time!
    If that doesn't solve it then you may have an issue with the cap or the lines.
    VXRed Arden OPC's Avatar
    3rd September 2016
    148
    Hello mate i had the same exact smell it's not something important you have that smell because you need to tight the cup of the fuel more..
    If this smell doesnt stop check also the fumes tank..
    31st December 2014
    1,576
    If tightening cap doesnt work get a new one, they tend to become perished over time
    17th October 2009
    3,172
    This happens to most Astra H cars. A new filler cap always fixes the problem. Hope that's all your problem is.
    18th August 2016
    42
    Thanks guys
    VXRed Wezinman's Avatar
    8th October 2016
    47
    As above new fuel cap exact same thing with my astra and that sorted it right out
    VXR enough insanejim69's Avatar
    18th July 2008
    4,193
    As above, its a common Astra H issue, but I am sure its filtered to other VX cars too. Doesn't hurt to pop a new one on and also have a look underneath when the engine is running and see if there is any dampness around the bottom of the engine or fuel lines etc, also worth looking around the engine bay too just to make sure.
    James
    VXRed trebble67's Avatar
    4th March 2016
    136
    I've found the best technique to screwing the cap on tight is to do it slowly. Try and hold off the 'click' for as long as possible
    Sent from my MI 5 using Tapatalk
