Results 1 to 4 of 4
    16th October 2016
    2
    Default Washer bottle removal/replacement
    Hi guys
    Wondering if anyone on here could tell me how difficult and how much hassle it is to remove/inspect the washer pump in my Astra h as it only works when it wants to
    VXR enough Ant21's Avatar
    29th September 2013
    1,504
    Much much easier to remove the bumper to gain access. It's clearly visible once it's off and you'll be able to get it from there.
    11th April 2016
    424
    You can access it pretty easy from the ns wheel arch just need to peel back the plastic cover Iirc
    20th January 2014
    2,153
    Probably clogged with green algae (a lot of people don't put in washer additive and it grows quite well in the summer months in tap water).
    Careful not to snap the pump when removing it. Get a lever down near the bottom to help pull it out in a straight line.
    Pic courtesy of Russ:
    Corsa is similar and done in a thread here;
    http://www.vxronline.co.uk/forum/sho...the-filter-out)
    OPC ÉIRE- Drop me a PM for Irish meets, group adds etc.
