Page 3 of 22 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 220
  1. #21
    12,917
    You know it. Nae carbon in sight either 😂
    Boring
  2. #22
    20th March 2016
    270
    I'm going to retrofit these for the Zaf in the new year. Unfortunately I have a bit of wiring to do but otherwise shouldn't be a bad job. Don't really want to be spending £240 on new looms. May buy the mirrors second hand if I can find them otherwise non oem mirrors new are £100 per pair.
    Sent from my GT-I9305 using Tapatalk
  3. #23
    VXR enough MikeyP247's Avatar
    2nd June 2014
    1,165
    Quote Originally Posted by Matt1982 View Post
    Yeah that would be pretty cool keep us posted Mikey
    Will do
    How many other models did/does have this option?
    Vectra?
    Insignia?
    Zaf?
    Anyone know? .....
    The Meriva VXR didn't have it as an option, but (depending on if you have the right body loom or not, same as Astra) it can be retrofitted easily or with difficulty. I had the loom so swapped the door looms out (had to change the motor plug) and the swapped the mirrors (Design had this option more readily apparently), plugged in the relay under the seats and changed the switch. Another VXROnline member has an earlier car and had to add 2 wires per side and then the same as me with the doors etc.
    MikeyP247
    Current: Astra 2.0 CDTi SE Sports Tourer
    Gone: Meriva VXR
  4. #24
    18th September 2009
    11,955
    Mine were factory fit. Can't do without them! Just wished they folded when locking / unlocking
    +1
    I am pretty awesome.
    BOOM
    the Moaning Mod
    Clique No: 7
  5. #25
    VXR enough Cal93's Avatar
    14th August 2011
    1,126
    I love them. More than the sat nav and Bluetooth in my old car.
  6. #26
    Are you VXR enough? COSWORTH's Avatar
    17th July 2013
    934
    I bought the kit from courts with the looms and had them fitted within a few hours well worth it - going to modify them to work with a timer off the central locking so they fold when you lock the car ��
  7. #27
    20th March 2016
    270
    If you could do a how to on that modification it would be really useful. I know a lot of us would want to do that. Thanks.
  8. #28
    17th July 2013
    934
    Quote Originally Posted by zaffy View Post
    You need to buy a few bits to do it there was some info posted here and a wiring diagram about 1 year ago will have a look see if I can find it
    If you don't want to do it I think Gcap I think they are called do it for about £150 but parts only cost £40 and wouldn't take long once you had taken door cards off and located live from central locking
  9. #29
    20th March 2016
    270
    Nice one. Only want to strip the car once
  10. #30
    18th September 2009
    11,955
    isnt there a how to already
    BOOM
    the Moaning Mod
    Clique No: 7
