Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 38 of 38
Thread: Blowing
  1. #31
    VXR enough V6spike's Avatar
    18th May 2013
    1,589
    so wrapping it with decent heat wrap could potentially be the answer? i'm guessing if its the flex part it may actually work, however if the gasket has failed then off it comes.
    2006 Arden Vectra VXR Estate. Bilstein B8 shocks (front), Eibach Prosport springs all round, Pioneer AVIC F970DAB HU, Pipercross and Ramair Custom Cones with ASH heat shield, MTECH Shortshifter, DO88 Intake kit, Custom Alloy pipework from Turbo to MAF.
  2. #32
    18th May 2013
    1,589
    cancel the above. some posts i've read are not pointing to it not being very good.
  3. #33
    Are you VXR enough? Jon1796's Avatar
    24th August 2015
    772
    Well at least I'm not taking it apart again to do it now.
  4. #34
    27th February 2016
    98
    How expensive was the new pipe?
  5. #35
    24th August 2015
    772
    £220 from gps
  6. #36
    Are you VXR enough?
    13th March 2015
    809
    What's it made of? Mild steel? Looks quite thin.
  7. #37
    24th August 2015
    772
    Metal..... I have no idea, the flanges will last longer than the car though that's a plus, I think????
  8. #38
    27th February 2016
    98
    stainless steel, i must use special electrode for weld
