Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    22nd March 2016
    64
    Default Few questions regarding A28
    Hi guys, some of you may or may not know, i am currently putting an A28NET engine into my VX220.
    I am planning on fitting a 20T hybrid turbo.
    3" decat exhaust with backbox bypass butterfly valve
    full charge cooler system due to space and rear mounting
    and is bolted to a Vectra VXR gearbox.
    Obviously due to being fitted to a VX220 the air con and power steering have been removed and will have custom brackets with idler pulleys for the auxiliary belt.
    What injectors would be best to get around the 400 mark? Also what toque figures am i likely to see around the 400 mark?
    My main aim is i want to hit the 400 mark if not more. When will i likely need to start looking into rods etc?
    cheers
    Al
    2011 Citroen C5 VTR+ Estate
    "The sensible car/ Dog taxi"
    2002 Pepper Red VX220 Stage 2 S/C
    "The fun car"
    Project Thread - http://www.vx220.org.uk/forums/topic...oject-unknown/
    VXRed blooded james400's Avatar
    22nd November 2015
    324
    550cc injectors will do the 400 ive got 850cc in my engine as im going for the 500+ mark now you will do 600+fpt at 400 be interesting to see how its going to put it down as it 2wd and in a very light body keep us up dated on this tho
    http://www.jzwtuning.com/product/saa...uel-injectors/
    22nd November 2015
    324
    What you doing about the dm flywheel you ruuning one or have a solid flywheel??are you running the oe ecu or you going standalone? Do you have in bolted in yet? And do you have photos ??
    22nd March 2016
    64
    Quote Originally Posted by james400 View Post
    So what would you think the max i will be able to get out of the turbo? Also to get 500+ are you doing internals?
    I'm hoping that 10-11" rear wheels along with the mid engine configuration will help put the power down if not... well then i don't know lower power?... lol
    i plan to remove the dual mass flywheel and replace with a solid lightweight and paddle clutch, ecu wise i will be running it with an AEM Infinity 708 (£2100). i do have it bolted in at the minute, just had it out to clean and paint to make it look like new before starting wiring. I have mocked up some driveshafts which ill be sending off to be made and have finished the exhaust. heres a few pics, ones of the engine in the car are old as haven't got any recent ones. Exhaust downpipes is fully finished and just need to fully weld up the back box and decat pipe. will be making a cat section later on down the line. also if back box sizes turn out to be too small and the exhaust is too loud i can increase by almost double the length.
    one of the car before engine conversion started
    "The fun car"
    22nd November 2015
    324
    Looking good i wouldn't think you would get much more over 400 with that turbo im running a gt35 for the internals thay have been rated to about 5/600 but its not been tryed as of yet as far as i know but we will see with my build. For the dm flywheel i looked into going solid and was put off buy it spoken to a few people who had done it in the vectra and to be fair you would have more problems with a solid one dont forget that the cranks are different from the vectra too so you would have to get a one-off flywheel make witch is hard to fid trust me ive been down this route.
    22nd November 2015
    324
    https://www.torquecars.com/tuning/dm...d-flywheel.php
    22nd March 2016
    64
    yeh i've read yours. i had considered going for a bigger turbo but don't think id ever get set off lol. i haven't bought a flywheel yet so may well stick with a dm if its better?... what diameter of pipe did you use to make your manifolds?
    "The fun car"
    22nd March 2016
    64
    Just read through that i think i'll stick with the dm flywheel as well tbh I'm hoping the car will come in under 1000kg and planning a long euro trip for when its done so want it to be as smooth a drive as possible
    "The fun car"
    22nd November 2015
    324
    Lol manifolds are 1.25" and link pipe is 1.5" i would run a gt30 in your or somthing around that size or even 2 gt28 stay with the dm flywheel much easier to deal with
    https://www.sachsperformance.com/en/...-opc-4x4-239kw
    22nd March 2016
    64
    2 turbos you say..... lol. what would the max power achievable be of a gt30?... sorry loads of questions. figuring if I'm going to do it do it right the first time...
    "The fun car"
