Results 11 to 20 of 26
  1. #11
    VXRed blooded james400's Avatar
    22nd November 2015
    324
    Yes same as me if your going to do something do it right first time ive seen 500 on a gt30 not on one of these tho but the turbo is capable for up to that.yes twin turbo not been done yet but there would be room for it from the look of it
  2. #12
    VXRed Griffin dai's Avatar
    11th May 2013
    238
    Sounds awesome!!
    You could try CG Motorsport for the clutch/flywheel. I sorted a deal with them a while back which might still be on, it's £100 off for UKsaabs & VXROL members so £650 plus delivery, might be back up to £750 now though. They do both the 666 organic and 777 6 paddle kits which includes a heavy duty cover and SMF. I've got the 777 kit on mine, no real issues and it's holding the torque fine, bit grabby in 1st, some clutch chatter at idle but appart from that you'd struggle to tell if there's a paddle clutch fitted. Worth a call anyway. I looked at a few clutch options for mine but SPEC stage 4 plus SPEC flywheel was around £1,200 so went with CG instead.
    Try Martin93t on here for the 550's he's the uk distributor for JZW.
    Saab 9³ v6 Aero
    JZW Stage 5 tune, Insignia VXR turbo, 550cc injectors, Evo 90mm IC, 3" system
    Quaife LSD, CG777 paddle clutch, BPS Short Shifter, Eibachs, B8's, Michellin PS4
  3. #13
    22nd November 2015
    324
    What engine code is you griffin a28 or z28??
  4. #14
    11th May 2013
    238
    No idea lol! B284
    Saab 9³ v6 Aero
  5. #15
    22nd March 2016
    64
    Saab then
    2011 Citroen C5 VTR+ Estate
    "The sensible car/ Dog taxi"
    2002 Pepper Red VX220 Stage 2 S/C
    "The fun car"
    Project Thread - http://www.vx220.org.uk/forums/topic...oject-unknown/
  6. #16
    22nd March 2016
    64
    I think the saabs are the same as the Z28 aren't they? Only two of the four cams VVT?...
    "The fun car"
  7. #17
    22nd November 2015
    324
    I'm pretty sure your is the z28 then witch have a different crank to the a28 so the flywheels are different
  8. #18
    22nd March 2016
    64
    Quote Originally Posted by james400 View Post
    What's the difference between the z28 and a28 cranks? I have a Z28 engine that I stripped for spare parts (sensors and that) to use on my a28 in the car.
    I'm guessing worst case I'd be able to just swap out the cranks?
    I was tempted to get a LY7 crank from the Cadillac CTS (3.6 version of ours) as it has a longer stroke so new rods and that crank will increase engine capacity to 3.2 which I basically what the Aussies have with their 3.2 holden engine
    "The fun car"
  9. #19
    22nd November 2015
    324
    Yes I'm the same but other way around lol the bolt paton is different if i could get hold of a cts crank i would do that too but big money
  10. #20
    22nd March 2016
    64
    I figure if I end up going to do the internals that'll be the time I'll do it. As it makes sense to me
    "The fun car"
