Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 49
  1. #11
    14,735
    Where did you purchase yours?
  2. #12
    VXR enough ChrisKing's Avatar
    23rd February 2015
    1,480
    Fb but theres fronts on ebay for 250 the noo
  3. #13
    14,735
    Ah right. All I can see on ebay is brake parts for the actual vectra.
  4. #14
    1st April 2016
    180
    Vectra set up I would be wary of. Increased weight will destroy the handling due to lugging all that unsprung weight with you. I did a similar mod on my Corsa years ago and it was the worst thing I did to the car.
    I would first off change pads/discs and proper fluid maybe with braided lines.
    Or the Brembo Megane calipers using Stock discs.
    Or Ksports.
  5. #15
    28th October 2016
    49
    Quote Originally Posted by ArcticH View Post
    Or Ksports.
    Hmmm, which model are they fitted to? Are they a direct bolt on replacament?
  6. #16
    Are you VXR enough?
    4th May 2013
    915
    I run Porsche brembos. They are the same as megane 225 and Clio 197 but seem cheaper for Porsche. The calipers and mounting brackets were about £300. Then you need braided hoses £59 and decent discs and pads. Iv ran standard discs and pads and they are crap. You will get a full kit for about £500
  7. #17
    28th October 2016
    49
    Quote Originally Posted by Vxrmotorsport View Post
    Thanks for that, does anyone do the kit or do you need to source bits on their own?
  8. #18
    Are you VXR enough?
    4th May 2013
    915
    Just source your own bits. I got calipers and brackets and ran my standard discs for ages but they didn't last and you can buy the conversion hoses on eBay
  9. #19
  10. #20
    28th October 2016
    49
