Results 1 to 10 of 15
Thread: Ecn code help
    VXR enough Matt1982's Avatar
    19th June 2016
    1,308
    Default Ecn code help
    Hey folks
    Had ecn13025 appear along with my eml light on first time I've had this one I'm assuming it's to do with o2 sensors??
    15th May 2013
    17,628
    First on by pre cat mate.
    Probably goosed.
    Best to pull it out and replace with a new one. Just make sure it's a Bosch one
    19th June 2016
    1,308
    Probably goosed.
    Cheers Ry
    Piss take is only changed it about 2 months ago for a Bosch one
    15th May 2013
    17,628
    Quote Originally Posted by Matt1982 View Post
    Cheers Ry
    Really? In that case I'd be looking at the AFR's instead. You should go get it mapped
    VXRacing ahead
    23rd February 2015
    586
    Was it a bosch one from euro car parts by any chance?
    19th June 2016
    1,308
    Quote Originally Posted by knight vxr View Post
    It was a Bosch one but from nevlock fella
    VXR enough Arctic martin's Avatar
    27th December 2012
    4,278
    I had that code bought one from same place as you and now the codes gone before I could even fit the new sensor
    WG Motorworks Fully forged Astra Vxr Arctic ...
    Rabbid tuned... TD Stage 3 hybrid, Piper valve springs, piper cams, klasen inlet manifold, Courtney cdti conversion, Airtec front mount intercooler, 3" scorpion exhaust, Turbosmart actuator, Forge recirc valve, Quaife LSD, Helix Clutch & SMF, Rear anti roll bar, blue & red SMD conversion , bi xenons and CD70
    19th June 2016
    1,308
    Quote Originally Posted by Arctic martin View Post
    Well had it on me dad's snap on diagnostic the code that it had thrown up was telling it that the readings from each sensor are different but pretty at one is flucuating on there but the one after the cat was just staying at one reading lol
    19th June 2016
    1,308
    Think I may have found the problem my exhaust was loose on the first join after the downpipe I only noticed because my tail pipe was sticking out a lot so I pushed on it and it moved real easy lol
    My point is I bet it was drawing in air from there and the sensors were getting confused?
    VXR enough stevenbarrowVXR's Avatar
    21st November 2013
    3,934
    Yeah id say that was the problem mate
    Rabbid Tuned Stage 4.5 - 355bhp - TD S3 Hybrid, AET ported exhaust manifold, TS 10psi actuator, TS recirc valve, Full 3" Piper decat non-res exhaust, Forge intercooler, AEM dual nozzle WMI kit, cdti hose with AEM cone, Regal cams, Klasen inlet manifold, Piper single valve springs, Percy retainers, PEC i-beam rods+ARP bolts, Skimmed Head, Protec 340lph fuel pump, Siemens 630cc injectors, AP front big brake kit, Vectra VXR rear brake conversion
