Results 1 to 10 of 10
    Are you VXR enough?
    4th May 2013
    886
    Default Suspension set up
    I have a new set of dap springs to fit and before I do is it worth going for a set of bilstein shocks. I only want to fit them once. Obviously bilstein is going to be a good setup but are the daps ok to use with my standard ids struts ? Thannks
    18th September 2009
    11,579
    most run daps with standard shocks as I do
    I am pretty awesome.
    BOOM
    the Moaning Mod
    Clique No: 7
    Are you VXR enough?
    4th May 2013
    886
    Are they ok like that ?
    18th September 2009
    11,579
    yeah iv had no problems, have had daps on for 5 years
    BOOM
    the Moaning Mod
    Clique No: 7
    VXR enough X8 DUD's Avatar
    26th October 2012
    2,588
    If you have IDS suspension as standard, id check with courts as not sure they are compatible (worth double checking anyway).
    I run daps with standard shocks, fine for road use. I debated b8's but eventual plan is to go fully adjustable so haven't bothered changing them over
    15th May 2013
    15,791
    DAP road spec are fine on standard shocks even with IDS
    It's the race spec ones that should ideally be run with a shortened damper like the B8
    But if you plan on doing dampers why not just go all out drop the DAPs and go B14 coils?
    Are you VXR enough?
    4th May 2013
    886
    I already have the dap springs. I don't want coilovers. I drive abroad once a year and can't live with the harsh ride. Even good ones are still to hard
    26th October 2012
    2,588
    B8's should be fine for what you need bud, comfy enough still without being too harsher ride. You run 18" or 19" wheels?
    Are you VXR enough?
    4th May 2013
    886
    I'm running 18s now
    26th October 2012
    2,588
    Will be fine then, 19's just run harshly in general.
