Results 1 to 10 of 11
    VXRed Sam_Night's Avatar
    28th November 2016
    67
    Default Pre-Cat delete on Z16LEX Engine
    All,
    Can anyone Recommend a pre-cat delete pipe and spacer so my EML doesn't show up?
    My car is an 09 so it would be for the Z16LEX engine model!
    Thanks as always guys
    Sam
    9th January 2017
    794
    Quote Originally Posted by Sam_Night View Post
    All,
    Sam
    I've got a toyo sports precat on my 09 corsa vxr fitted without a lambda spacer. I think you only need a spacer if you are removing the main cat.
    28th November 2016
    67
    Can anyone also tell me if this is any good:
    http://www.txautosport.co.uk/vauxhal...pipe-346-p.asp
    As i can't find the Toyo Sports one!
    VXRacing ahead churchwxm's Avatar
    11th October 2016
    701
    I had one for the A16 (main cat, but same pipe more or less) and it was sound. Fitting the turbo clamp was tricky but I got there in the end. Some people have had trouble with fitting, and after just putting a Cobra decat on with the same clamp in literally seconds, i can only assume the flange is thicker on the TX pipe.
    If you get a bad one they seem helpful and will swap it (they said they would for me), so personally i would go for it as mine turned out just what i was after at the time.
    As for a spacers, just don't get a straight one, 90 degree with a small hole is what your after: http://www.ebay.co.uk/itm/Decat-Exha...-/331922544526
    If your doing your pipe yourself do some searching on here regarding the clamp fitting, its awkward first time and you have to get the clamp the right way round as it only seals fitted one way.
    Shame you haven't got the A16, you could of had my 2 month old one for £35.
    23rd May 2013
    2,105
    Toyo one;
    http://www.ebay.co.uk/itm/EXHAUST-DE...kAAOxyc2pTY3EZ
    9th January 2017
    794
    Are the spacers recommended on a z16 pre cat delete?
    23rd May 2013
    2,105
    No.
    You only need a 90 degree spacer on the Z16 main cat delete (under the car)
    11th October 2016
    701
    No.
    That makes sense as the lambda port is behind the main cat on the Z16.........................All this A16/Z16 zaust talk is doing my head in, I'm done with it!!!
    If the OP does get a TX one i suggest getting some proper bolts, the ones supplied are gash and i sheared mine so bought stainless.
    8th December 2015
    83
    All,
    Sam
    Been running my precat delete on my 09 plate for 2 months now , no EML light. Only need the spacer for main cat, as stated
    23rd May 2013
    2,105
    Quote Originally Posted by churchwxm View Post
    all this a16/z16 zaust talk is doing my head in, i'm done with it!!!
    lol!
