Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 58
  1. #21
    15th May 2013
    17,536
    Not bad value that really
  2. #22
    VXR enough stevenbarrowVXR's Avatar
    21st November 2013
    3,932
    It really is mate and the benefits it gives you when mapping are massive, for me it be pointless for you to spend money on a new cooler when you could buy wmi as it better than any cooler you could buy and then you get other benefits from it as well when tuning
    Rabbid Tuned Stage 4.5 - 355bhp - TD S3 Hybrid, AET ported exhaust manifold, TS 10psi actuator, TS recirc valve, Full 3" Piper decat non-res exhaust, Forge intercooler, AEM dual nozzle WMI kit, cdti hose with AEM cone, Regal cams, Klasen inlet manifold, Piper single valve springs, Percy retainers, PEC i-beam rods+ARP bolts, Skimmed Head, Protec 340lph fuel pump, Siemens 630cc injectors, AP front big brake kit, Vectra VXR rear brake conversion
  3. #23
    14,730
    Is it complicated to set up?
  4. #24
    21st November 2013
    3,932
    Naw really simple mate, 2-3 hours fitting time, easy enough to do if you can do wiring and are competent mechanically, its basic stuff. If you actually mean dialling it in then that just takes a bit of playing with settings on the controller until it does what you want it to do but again its basic stuff and when getting mapped the tuner can fine tune it ever more but you can set it up yourself with a bit of common sense
  5. #25
    14,730
    I'd be no good
  6. #26
    21st November 2013
    3,932
    Well if you know anybody who competent with electrics etc that should be enough to do the job
  7. #27
    14,730
    Any wiring to the cockpit?
  8. #28
    14,730
    You got any pics of your car Steven? Bay too maybe. It's quite an awesome spec
  9. #29
    21st November 2013
    3,932
    Check out my progress thread mate, loads of pic on there of my bay and the wiring done when we were fitting the wmi. Basically running wires from the pump and tank to the controller which i placed in glovebox so came down that side of the car
    http://www.vxronline.co.uk/forum/sho...?243710-my-vxr
    Dont really update my thread much anymore because my photobucket doesnt really work properly anymore for some reason and i dont know any other way to upload pics lol
  10. #30
    14,730
    Tapatalk mate lol. That's what I use now
