Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 31 to 40 of 58
  1. #31
    VXR enough stevenbarrowVXR's Avatar
    21st November 2013
    3,934
    Must give it a go mate thanks
    Rabbid Tuned Stage 4.5 - 355bhp - TD S3 Hybrid, AET ported exhaust manifold, TS 10psi actuator, TS recirc valve, Full 3" Piper decat non-res exhaust, Forge intercooler, AEM dual nozzle WMI kit, cdti hose with AEM cone, Regal cams, Klasen inlet manifold, Piper single valve springs, Percy retainers, PEC i-beam rods+ARP bolts, Skimmed Head, Protec 340lph fuel pump, Siemens 630cc injectors, AP front big brake kit, Vectra VXR rear brake conversion
  2. #32
    Are you VXR enough?
    4th May 2013
    915
    Where do you run the pipe from the tank to the bay ?
  3. #33
    21st November 2013
    3,934
    Through the car along with the wiring amd out through the grommit in the bulkhead
  4. #34
    21st August 2014
    196
    well guys ive bought a cooler does anyone know what pipe work is needed
  5. #35
    Are you VXR enough?
    4th May 2013
    915
    Did you buy a universal cooler ? Getting all the pipe work will end up costing as much as a complete kit
  6. #36
    21st August 2014
    196
    no i bought the cooler 700mm 300mm 86mm custom made from a rally shop that deal with fordge and airtec stuff and also make custom coolers and the price and test results are more or less the same results as the airtec and fordge coolers
  7. #37
    Are you VXR enough?
    4th May 2013
    915
    How much are they ?
  8. #38
    21st August 2014
    196
    £119 the tx and dna ones are no where near as big and the size im getting are tested up to 700bhp which i wont be getting no where near that i will post pic up when i collect it
  9. #39
    21st November 2013
    3,934
    Yeah but the pipework to make it fit mate will cost a fortune mate
  10. #40
    21st August 2014
    196
    narrr few bends and joins it just knowing how many soild pipes and silicon ones i will need ash auto are pritty good and cheap and used them loads of times never had a problem with there hoses
