Results 1 to 9 of 9
    15th December 2015
    61
    Default Boost issue ( with video link attached )
    Hi guys ,
    Just wondering if anyone can help? I fitted a crossover delete a few weeks back to my astra and since the car some times only boosts to 0.5 bar in certain gears and in other gears it sometimes boosts to 1.0 bar also the car use to do the clock and now only does 140 flat out, this is really frustrating me now as i dont know whas causing this. There is do dash error codes eather, please see link attached of a short video - https://vimeo.com/199051127?ref=em-share
    VXRed blooded Rksmith's Avatar
    15th December 2016
    255
    Could be boost solenoids bud.
    VXRacing ahead
    17th January 2013
    557
    You on cone mate or box
    15th December 2015
    61
    Got a cone on mate but had a the same cone on b4 i fitted the crossover delete pipe.
    VXRacing ahead
    17th January 2013
    557
    Wot cone is it mate is it deffo 80mm
    15th December 2015
    61
    Its just a universal 1 pal , y would that effect it like?
    VXRacing ahead
    17th January 2013
    557
    Yes mate deffo that kind of problem can be caused my air not flowing properly either by a restriction or a leak as in split pipe some where or lose jubilee clip
    15th December 2015
    61
    Well must be that then as all boost clamps are tight, il get 1 ordered now. Cheers pal
    VXRacing ahead
    17th January 2013
    557
    Might not be that tho mate I only paid around £45 for my aem cone from eBay so not to bad is your crossover delete pipe solid
