Results 1 to 3 of 3
    22nd January 2017
    2
    Default Decat ? Air filter ?
    Just purchased a monaro vxr 5.7 lovely clean car. Just a after bit of advice , it has a wortec exhaust but I didn't no if it was worth decating it and replacing the filter for either cone type or cold air induction type , would decating put the management light on also thanks any advice appreciated
    VXRed Leeky's Avatar
    8th September 2016
    64
    From what I have heard (I'm sure someone will correct me if I am wrong), the stock cats are very free flowing and you pretty much get zero gains from upgrading or decatting the cars. So unless you are going for big power (800bhp+) then they are not a bottleneck.
    Im still getting to grips with the LS engines but i've come from a background of tuning Japanese V8's which do tend to trigger engine codes when you decat them. This being because there is a pre/post cat lambda, which expects the flow to be within a certain range. Decat causes reads outside the range so it thinks there is a fault. Id expect the LS engines to be the same.
    I have a used K&N Induction Kit if you are interested. I just removed it on my 6.0 VXR.
    I believe these are about £250 new. Would take £100 cash for it. Its got all the pipe/heat shield/fittings/brackets/nut/bolts etc
    2005 Monaro 6.0 - Sting Red
    Duspeed OTR CAI, X-Force Extractors, X-Force Twin 3" Mild Steel Exhaust, Advan AD08R Tyres
    7th July 2012
    177
    My vxr8 used to throw codes after the exhaust and cats were done but I had MF disable those codes and problem solved
