Page 11 of 13 FirstFirst ... 9 10 11 12 13 LastLast
Results 101 to 110 of 126
  1. #101
    19th April 2017
    18
    My seats haven't come away. They just don't tip forward to allow passengers in the back. Not that i allow many passengers in like. It's my car and my car only! No riff raff allowed. Hehe.
  2. #102
    22nd July 2017
    41
    Messaged the link on Facebook Tuesday, received the clips yesterday free of charge. Heroes.
    However, guide to fitting them isn't too clear, anybody whose successfully used them to repair the seats share some advice?
  3. #103
    VXRed R21TTY's Avatar
    5th January 2018
    38
    Finally managed to work out these clips from recaro! Had them about 3 months and only just worked it out. Quite easy to do once you work them out ����
  4. #104
    20th June 2017
    139
    are you going to do a step by step thread?
  5. #105
    5th January 2018
    38
    Quote Originally Posted by raz0083 View Post
    Basically where the leather has come away if you pull it and look behind the seat there is a channel of plastic.
    Also attached to the leather is a thick rubber.
    So what you need to do is get the clip which is u shaped and slide the u over the edge of the channel.
    Hold the clip in position and then push the hard rubber up in to the channel where you are holding the clip.
    Try using something plastic that’s not too sharp when your pushing it incase you rip the seat. (I used a screwdriver with a kitchen towel on the end)
    Repeat that all the way down keeping the clips about 4 inches apart if you have enough of them.
    It’s really hard to explain lol. Unfortunalty I used all my clips and done both seats otherwise I would just do it again with pictures or a video. Hope this helps ����
  6. #106
    5th January 2018
    38
    I have sent a reply on how to do it but it has to be authorised for some reason.
  7. #107
    15th January 2014
    630
    Quote Originally Posted by R21TTY View Post
    Would really like this reply to be authorised as I can't work it out haha
  8. #108
    5th January 2018
    38
    Quote Originally Posted by Brucerutherford View Post
  9. #109
    21st March 2017
    8
    Are people still having any luck with Recaro sending out fixing kits from the info I've received its a bit hit and miss
  10. #110
    22nd July 2017
    41
    From the Facebook link on the previous page I got loads of clips posted to me for free.
    Instructions were garbage though and I couldn't get them to work. Although that's probably on me.
