Results 1 to 10 of 13
Thread: Air bag fault
    VXRed Pablomilner1987's Avatar
    20th January 2017
    105
    Default Air bag fault
    Changed all my dash lights to green led bit since putting it back together the air bag lights are flashing constantly. I've checked the underseal wiring. I've tried turning igniting on and holding button down. Also disconnected the battery for a solid hour yet the problem still persists on flashing. Please help..
    25th January 2010
    1,084
    Only can suggest a auto electrician looks at it
    11th January 2006
    2,203
    have it code read might just need the fault code clearing
    VXRed Wallace-vxr's Avatar
    4th January 2017
    91
    Check the wiring under
    Passenger seat hasn't been knocked , try fiddling with them
    Making sure that they are pushed in properly
    20th January 2017
    105
    Quote Originally Posted by timmee View Post
    Is that a tech 2 job or would a ecu reader do the job
    20th January 2017
    105
    Quote Originally Posted by Wallace-vxr View Post
    Thanks dude I did try that before posting but nothing. There really doing my head in now lol
    23rd May 2013
    1,822
    Were they canbus compatible leds?
    VXRed blooded hoskins's Avatar
    19th December 2013
    262
    I heard if you disconnect the hazard/airbag/door lock buttons/circuit board.. you shouldn't turn ignition on with it disconnected, I put mine back after smd converting, and had the same issue, just left it for about a month and they went out and back to normal eventually.
    20th January 2017
    105
    Quote Originally Posted by hoskins View Post
    Yea I think I may of had the ignition on. It's been 3 months now and still not gone out lol
    19th December 2013
    262
    Maybe disconnect battery for half hour to reset ecu,
    I know someone who coverd the warning bulbs with bits of electrical tape, underneath the speedo and buttons, to hide them as the Mot was due the week it happened lol
