Results 1 to 8 of 8
    VXRacing ahead Giancarl03's Avatar
    18th February 2014
    549
    Default Power gained from full decat
    Hi All,
    What would be the typical power gains resulting from removing the both cats?
    Being a turbo aspirated engine one would expect a quicker turbo spool but would there be a power gain? Any comments?
    -=2014 Astra OPC=-
    Summit White|Aero Pack|206kW|400Nm|1530kg
    VXRed blooded Klystron's Avatar
    2nd June 2015
    461
    From the WG website, removing the first cat 8 - 10BHP improvement removing the second cat another 5BHP. This does not include the remap gains.
    Having a sports cat fitted and no first cat, mine is limited on power output due to the amount of gas that can flow through the sports cat.
    3rd March 2013
    1,357
    I had both cats replaced with decats, added an RSS intake and after map made 336bhp 402lbft (251kW 545nm)
    Summit White GTC - GONE
    Replaced by Mk7 5dr Golf R
    My Progress Thread
    10th January 2015
    442
    Default decat
    both cats removed 325bhp after map could have gone more on bhp but wanted a safe mapp rather than chasing bhp
    26th November 2015
    106
    Quote Originally Posted by StuW View Post
    Can you add a video of this, as i want to see if mine sounds the same ... im running the exact same specs except im not sure if mines double decat as cobra doesnt state this on there systems.
    i have a turbo back non res system and had the cat replaced with a decat. so not sure if its double or not :') not too technical with all this stuff
    3rd March 2013
    1,357
    https://www.instagram.com/p/7lgmQaucWR/ thats with a Remus non res cat back aswell.
    My Progress Thread
    VXR enough Cal93's Avatar
    14th August 2011
    1,142
    Good gains there Stu!
    3rd March 2013
    1,357
    Quote Originally Posted by Cal93 View Post
    Would have squeezed a wee bit more out if I got the map tweaked with the cat back. All back to standard and sold now
    My Progress Thread
