Results 1 to 6 of 6
    VXRed Jakedunn1000's Avatar
    4th August 2016
    57
    Default Brakes squeaking after changing pads and disks
    As above, I put copper grease on the sliders and the back of the pads and it's making a weird sqealing noise sometimes, mainly only makes the noise when going slow or turning left. Could it be something as simple as the heat shield catching the brakes?
    Guest
    24th April 2016
    245
    Bet its the break disc shield, turn full lock to see it and pull it away from disc by bottom and do same with right lock
    4th August 2016
    57
    Quote Originally Posted by Markandjess View Post
    Cheers, I'll give that a go tomorrow. Is the shield actually needed?
    23rd May 2013
    2,105
    Not really, it just keeps stones etc away from the disc.
    In 10 years time it will have rotted away and fallen off by itself like on most cars without causing any issues.
    4th August 2016
    57
    Ah right ok, I'll take a look. Thanks mate
    16th February 2017
    21
    Did you sort this bud..I have the same 😢
    Sent from my SM-G935F using Tapatalk
