Results 1 to 6 of 6
    30th December 2014
    2
    Default Air-co manual to climate control
    Hi all
    Does anyone know if it is a straight forward plugin swap to upgrade from Manual air-co to Climate control, with Climate control Fascia?Climate Control Fascia.jpg
    Cheers Pancellorum
    VXR enough Keif's Avatar
    12th March 2009
    1,900
    Fancy taking your dash out? and swapping your dash loom and Heater unit?
    Currently Driving - Lotus Carlton - Astra TwinTop - Meriva VXR - Nova GSi
    VXRacing ahead joff-turbo-nova's Avatar
    6th January 2012
    696
    Quote Originally Posted by Keif View Post
    That will be a no its not plug and play - there is a dash sensor plus the dash loom that needs changing out before you get anywhere near it working - you'll probably have to fiddle with the BCM settings with TechII as well to activate the correct settings.
    I think this is up there with the AFL's on the amount of things you need to change to get working!!
    Joff
    Still not doing standard
    Meriva Z20LET/LEH project
    15,489
    I'm Mr retrofit at the moment, but there's no way in hell i'd ever attempt to retrofit climate lol
    25th January 2010
    1,095
    Begs the question why would you want to change to climate taking into consideration that it's a old motor -- what's the point
    12th March 2009
    1,900
    Quote Originally Posted by Brother Leo View Post
    Because you can. It's called fitting upgrades to your car. Some are easy. This one isn't.
