Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    VXRed tomadcockvxr's Avatar
    16th May 2015
    43
    Yeah it needs sorting asap though 😊
  2. #12
    VXRacing ahead iamphil's Avatar
    9th January 2017
    532
    Quote Originally Posted by tomadcockvxr View Post
    I thought if you uprated the turbo you would need to get it mapped to suit your current modifications. You're pretty much asking for trouble by fitting it without mapping mate.
  3. #13
    16th May 2015
    43
    Yeah I'll get it mapped it will still run okay for now, just need to sort the boost leak out mate.
  4. #14
    16th May 2015
    43
    *Update* I've found a very small leak on boost pipe coming out of the turbo connecting to the intercooler. It's on the connector of the intercooler. But I don't think that would cause all the noise I'm hearing surely?
  5. #15
    16th May 2015
    43
    *Update* I've sorted the small leak out and checked the recuirc valve, all okay. Still getting the loud whistle and can't seem to pin point the leak..
  6. #16
    VXRacing ahead
    23rd February 2015
    578
    If no leaks on boost hoses have you checked where the exhaust manifold bolts to the head? Leaking from gasket.
    Sent from my SM-G935F using Tapatalk
  7. #17
    16th May 2015
    43
    I checked all them today, they are all tight and can't feel anything coming out from there. Also does anyone know how to change the title of this thread? As I didn't check it before I posted it 😂
  8. #18
    10th September 2016
    138
    Check your compressor housing bolts
    2009 Arden Blue Corsa VXR
  9. #19
    16th May 2015
    43
    I'm sure I checked them before I put it in but I'll give them a try worth a shot!
