Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 34
  1. #11
    VXRed Vxrtony83's Avatar
    30th March 2016
    180
    It feels like it just wants to pull left on say a bends even with just coasting it round...
    The car has always pulled to
    Left slightly...not badly
    Just something don't feel right when chucking a hardish right turn
    Notice it more on roundabouts
  2. #12
    18th February 2007
    51,323
    Quote Originally Posted by Vxrtony83 View Post
    Spend the money and have it checked out on a Hunter alignment machine - google and you'll find one in your area.
    Astra
  3. #13
    VXRacing ahead Dryburgh27's Avatar
    19th August 2011
    559
    +1 get the alignment and suspension checked out somewhere else. Sounds like it's not being done properly
  4. #14
    30th March 2016
    180
    Quote Originally Posted by Dryburgh27 View Post
    I've been to 4 different places...every time is all tracked up feels blinding can chuck it in corners and it holds...but as said after a week or so goes all loose again
  5. #15
    VXRacing ahead vexorg's Avatar
    8th March 2015
    703
    When you take it back to each, does it need adjusted? how far out each time?
    Could something like the subframe or lower arms bolts not be fully tightened and it can move with weight on it?
    David
  6. #16
    18th February 2007
    51,323
    Has one of those places had the Hunter equipment?
    And like vexorg asks - when it's taken back have they confirmed it's changed from the initial correction they did?
    Astra
  7. #17
    30th March 2016
    180
    To be honest ain't noticed...can check there tho
    It's only needed adjusting once...but is weird how it goes all sloppy again
    Might do the anti roll bar bushes as not done them yet ?
  8. #18
    8th March 2015
    703
    So 3 times they didn't do anything and it got better all on it's own?
    David
  9. #19
    30th March 2016
    180
    Quote Originally Posted by vexorg View Post
    Nah been in one place twice on which it was out a little hit so redone it... and two other places...1 place said they couldn't do anything..the other place checked and just undone what they normally do and just tightened them back up and felt fine again...I've spoke to the bloke he said bring it back in if I can this week
    Don't know any other places that could look into it further as meaning a proper suspension place not just a tyre palace with alignment machines
  10. #20
    8th March 2015
    703
    Don't follow you. Usually any place I've been to will check it first before lifting a spanner. And if it's ok they send you off with no charge.
    David
