Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 34
  1. #21
    VXRed Vxrtony83's Avatar
    30th March 2016
    180
    Quote Originally Posted by vexorg View Post
    Don't follow you. Usually any place I've been to will check it first before lifting a spanner. And if it's ok they send you off with no charge.
    Lol
    They do check it all but can't see a thing wrong...but on one accession the alignment was out not bay loads...
    Gonna replace my roll bar bushes...then start over again from there
  2. #22
    VXRacing ahead vexorg's Avatar
    8th March 2015
    703
    Anti roll bar won't affect the steering much, just body roll.
    David
  3. #23
    30th March 2016
    180
    Can't think of what else to change
    Top mounts are new too
    Will try find a proper suspension and alignment place...
    But trying to find one near me is tricky
    There is one but will never put my car in there again !
  4. #24
    Are you VXR enough? Jon1796's Avatar
    24th August 2015
    983
    Tyre pressure low or over will cause same.
  5. #25
    8th March 2015
    703
    It would be funny if the tracking places were blowing the tyres up each time as he has a slow leak.
    David
  6. #26
    30th March 2016
    180
    Tyre pressures are 38 at the front and 35 at the back
    That's first thing I checked
  7. #27
    24th August 2015
    983
    Is there any Camber adjustment or are they fixed. plus was it wet, dry
  8. #28
    30th March 2016
    180
    Forgot I had them lol....they are spot on to be honest...they have never moved when I've been back in there
    It's in the dry...ain't really rained that much really
  9. #29
    24th August 2015
    983
    Did this start before you changed to coilovers or after.
  10. #30
    30th March 2016
    180
    It's was like it before coilovers
    Was perfect for ages other than being stupidly low...then one day just all felt loose...then I changed all the bushes and droplinks as they was looking worn...had it all aligned up was fine for about a month or so then this is started happening
